[AG-TECH] Re: Enter Venue Error.
Thomas Uram
turam at mcs.anl.gov
Wed Jun 4 10:23:19 CDT 2003
The exception raised and its temporary nature indicate that your clock
is probably not set accurately. Make sure your clock is set reasonably
accurately, using a network time server if possible.
This is necessary because proxy certificates are valid within a
particular time window. If your clock is set later than the clock of
the server, for example, the proxy you create will be regard as "not yet
valid" by the server. Eventually, the server time reaches the start of
your proxy validity period, so the server accepts the proxy as valid.
Tom
Andrew Bolyea wrote:
>Well, I don't think anything has changed in the last five minutes. I thought I would try to connect one last time, this time it worked. Fourth time (starting the VenueClient) was the charm I guess... not sure why though.
>----- Original Message -----
>From: Andrew Bolyea <andrew.bolyea at sheridanc.on.ca>
>Date: Wednesday, June 4, 2003 10:37 am
>Subject: Enter Venue Error.
>>I am also having difficulty connecting to the default venue with
>>AGTk2.0. It worked fine yesterday afternoon, but for some reason
>>not this morning. Any ideas? Thanks.
>>Error Message:
>>You have not entered the venue located at
>>https://vv2.mcs.anl.gov:9000/Venues/default.
>>An error occurred. Please, try again.
>>Note: Read VenueClient.log for more detailed information
>>VenueClient.log
>>06/04/03 10:21:49 3824 AG.CertificateManager None:972 DEBUG Proxy
>>C:\DOCUME~1\AG\LOCALS~1\Temp\proxy is valid
>>06/04/03 10:21:49 3824 AG.Types None:972 DEBUG Set history url:
>>06/04/03 10:21:50 3824 AG.Types None:972 ERROR
>>bin.VenueClient::EnterVenue failed
>>Traceback (most recent call last):
>> File "VenueClient.py", line 676, in EnterVenue
>> warningString = VenueClient.EnterVenue( self, URL )
>> File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py",
>>line 264, in EnterVenue
>> (venueState, self.privateId, streamDescList ) = Client.Handle(
>>URL ).get_proxy().Enter( self.profile )
>>packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3650, in
>>__call__ return self.__r_call(*args, **kw)
>>packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3670, in
>>__r_call self.__hd, self.__ma)
>>packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3570, in
>>__call config = self.config)
>>packages\AccessGrid\hosting\pyGlobus\Client.py", line 184, in call
>> r.endheaders()
>> File "C:\Python22\lib\httplib.py", line 695, in endheaders
>> self._send_output()
>> File "C:\Python22\lib\httplib.py", line 581, in _send_output
>> self.send(msg)
>> File "C:\Python22\lib\httplib.py", line 548, in send
>> self.connect()
>> File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 1079,
>>in connect
>> self.sock.connect(self.host, self.port, self.io_attr)
>> File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 663,
>>in connect
>> raise ex
>>GSITCPSocketException: an authentication operation failed
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030604/c1061e9a/attachment.htm>
