[AG-TECH] Re: Enter Venue Error.
Andrew Bolyea
andrew.bolyea at sheridanc.on.ca
Wed Jun 4 09:47:48 CDT 2003
Well, I don't think anything has changed in the last five minutes. I thought I would try to connect one last time, this time it worked. Fourth time (starting the VenueClient) was the charm I guess... not sure why though.
----- Original Message -----
From: Andrew Bolyea <andrew.bolyea at sheridanc.on.ca>
Date: Wednesday, June 4, 2003 10:37 am
Subject: Enter Venue Error.
> I am also having difficulty connecting to the default venue with
> AGTk2.0. It worked fine yesterday afternoon, but for some reason
> not this morning. Any ideas? Thanks.
> Error Message:
> You have not entered the venue located at
> https://vv2.mcs.anl.gov:9000/Venues/default.
> An error occurred. Please, try again.
> Note: Read VenueClient.log for more detailed information
> VenueClient.log
> 06/04/03 10:21:49 3824 AG.CertificateManager None:972 DEBUG Proxy
> C:\DOCUME~1\AG\LOCALS~1\Temp\proxy is valid
> 06/04/03 10:21:49 3824 AG.Types None:972 DEBUG Set history url:
> 06/04/03 10:21:50 3824 AG.Types None:972 ERROR
> bin.VenueClient::EnterVenue failed
> Traceback (most recent call last):
> File "VenueClient.py", line 676, in EnterVenue
> warningString = VenueClient.EnterVenue( self, URL )
> File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py",
> line 264, in EnterVenue
> (venueState, self.privateId, streamDescList ) = Client.Handle(
> URL ).get_proxy().Enter( self.profile )
> packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3650, in
> __call__ return self.__r_call(*args, **kw)
> packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3670, in
> __r_call self.__hd, self.__ma)
> packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3570, in
> __call config = self.config)
> packages\AccessGrid\hosting\pyGlobus\Client.py", line 184, in call
> r.endheaders()
> File "C:\Python22\lib\httplib.py", line 695, in endheaders
> self._send_output()
> File "C:\Python22\lib\httplib.py", line 581, in _send_output
> self.send(msg)
> File "C:\Python22\lib\httplib.py", line 548, in send
> self.connect()
> File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 1079,
> in connect
> self.sock.connect(self.host, self.port, self.io_attr)
> File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 663,
> in connect
> raise ex
> GSITCPSocketException: an authentication operation failed
