[AG-TECH] Ag2.0 Install on Debian Linux - possibly also on	KNOPPIX?
    Grzesiek Sedek
    grzesiek at mi2.hr
    Tue Jun  3 20:34:39 CDT 2003
I did one- it's hardly an alpha i would say- I've just included vic and
rat witch is enough for all new people I'm recruiting ;-) , mostly
without multicast so connection is made through quickbridge, once I'll
get more time I'm planning to remaster it with full AG support.
You can download it from:
http://www.jinxt.net/knoppix.iso
its just 200Mb
Keep me updated please!
Grzesiek.
On Tue, 2003-06-03 at 14:27, Douglas Baggett wrote:
> I'd be interested in any issues you might have. We are thinking of
> rolling a KNOPPIX livecd with the AGGrid software installed. It might be
> a good way for somebody to try out the grid without having to install it
> (we'll see!). Since Knoppix is based off of debian I'd imagine we will
> have similar issues.
> I'll be following your thread with interest, I'll post if we run into
> any strangeness.
> Has anybody else out there thought creating a livecd linux AG PIG?
> -Doug Baggett
> CISE/NSF/OAD
> Jason wrote:
> > I'm working on trying to install the Ag2.0 software on Debian and have
> > tried to use the rpm's and even gone as far as using alien to convert
> > the rmps to debian packages.
> > Using the instructions at
> > http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid I get errors.
> > The problem I have run into either way is that the setup-gsi script is
> > failing while executing grid-security-config. The grid-security.config
> > file is created just fine, but there is some problem I can't resolve
> > when it configures. The script is bailing out at line 133 of
> > /usr/lib/globus/setup/globus/setup-gsi.pl if that helps anyone who may
> > offer a response.
> > My question is this: Can I install from the CVS source and where would
> > information about installing from the CVS source be located? I have
> > all the prerequisite software that is available in debian packages
> > (Python2.2, libwxgtk2.2, libwxgtk2.2-python, python logging) installed
> > and it appears to be ready, but the error above has me stuck in my
> > tracks.
> > Thanks,
> > Jason Hill
> > jahill at scl.ameslab.gov
> > Ames Laboratory, SCL
> > 310 Wilhelm Hall
> > Ames, IA 50010
