[AG-TECH] Ag2.0 Install on Debian Linux - possibly also on KNOPPIX?
Douglas Baggett
dbaggett at nsf.gov
Tue Jun 3 08:27:24 CDT 2003
I'd be interested in any issues you might have. We are thinking of
rolling a KNOPPIX livecd with the AGGrid software installed. It might be
a good way for somebody to try out the grid without having to install it
(we'll see!). Since Knoppix is based off of debian I'd imagine we will
have similar issues.
I'll be following your thread with interest, I'll post if we run into
any strangeness.
Has anybody else out there thought creating a livecd linux AG PIG?
-Doug Baggett
CISE/NSF/OAD
Jason wrote:
> I'm working on trying to install the Ag2.0 software on Debian and have
> tried to use the rpm's and even gone as far as using alien to convert
> the rmps to debian packages.
> Using the instructions at
> http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid I get errors.
> The problem I have run into either way is that the setup-gsi script is
> failing while executing grid-security-config. The grid-security.config
> file is created just fine, but there is some problem I can't resolve
> when it configures. The script is bailing out at line 133 of
> /usr/lib/globus/setup/globus/setup-gsi.pl if that helps anyone who may
> offer a response.
> My question is this: Can I install from the CVS source and where would
> information about installing from the CVS source be located? I have
> all the prerequisite software that is available in debian packages
> (Python2.2, libwxgtk2.2, libwxgtk2.2-python, python logging) installed
> and it appears to be ready, but the error above has me stuck in my
> tracks.
> Thanks,
> Jason Hill
> jahill at scl.ameslab.gov
> Ames Laboratory, SCL
> 310 Wilhelm Hall
> Ames, IA 50010
