[AG-TECH] ARM & VRM Corba errors
Ivan R. Judson
judson at mcs.anl.gov
Mon Jan 27 20:23:50 CST 2003
Hey Markhus,
You can check cvs -d:pserver:anonymous at ag-cvs.mcs.anl.gov:/cvsroot to see if
there's anything newer.
The modules to check out would be:
AG
ag-dep
ag-linux-dep
ag-src
ag-vic
ag-windows-dep
dppt
VV
We'll be working to unify these together into the AG module as we have time.
More importantly we'll be focusing on getting AG 2 ready for the alpha
(coming to a town hall soon, bum bum bum).
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Markus Buchhorn
> Sent: Monday, January 27, 2003 7:35 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] ARM & VRM Corba errors
> G'day y'all
> We're just bringing up our first full node, using RH8.0 on
> the audio/video machines. We're getting an error when
> starting the eventlistener, the same as Tom Coffin mentioned
> two years back :-)
> http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/200
> 1/01/msg00027.html (see below).
> Following Bob's comments in the archives:
> - Our RPMs are from that obscure snapshot directory of Bob's
> (number 006 - which apparently is the latest?).
> - I checked the A/Vrm-eventlistener scripts, which pointed
> to the older jdk (117) java. Pointing them to the "newer"
> (jre122) java only helped in the sense that it no longer
> opened the OBnnnnn.jar files at all and complained about 'no
> such method's :-)
> - We get the same error regardless of whether the
> event-monitor is running on the display machine or not, go figure.
> - the display machine is running the 1.2 agdisplay bundle.
> (The JRE java seems a bit odd in the way it opens noncore jar files?)
> Any suggestions greatly appreciated. Is there anything newer
> in the CVS areas? Or are there any rpm's we've missed? (I'd
> expect different errors in that case).
> Bring on 2.0 Ivan! :-)
> Cheers,
> Markus
> >[root at ag1-audio root]# arm-eventlistener
> >Didn't find name service: org.omg.CORBA.ORBPackage.InvalidName
> >Got event channel
> >org.omg.CosEventChannelAdmin.StubForEventChannel at 80c77d3
> >Got ANY type 16
> >channel listener caught org.omg.CORBA.BAD_OPERATION:
> > at ag.MediaEventHelper.extract(MediaEventHelper.java:37)
> > at ag.SdpChannelListener.push(SdpChannelListener.java:88)
> > at
> >org.omg.CosEventComm._PushConsumerImplBase._OB_op_push(_PushC
> onsumerImplBase
> >.java:41)
> > at
> >org.omg.CosEventComm._PushConsumerImplBase.invoke(_PushConsum
erImplBase.java
> >:109)
> > at com.ooc.CORBA.BOA._OB_dispatch(BOA.java:1301)
> > at
> >com.ooc.CORBA.GIOPServerWorker.dispatchRequest(GIOPServerWork
> er.java:417)
> > at
> >com.ooc.CORBA.GIOPServerWorkerThreaded.dispatchRequest(GIOPSe
> rverWorkerThrea
> >ded.java:317)
> > at
> com.ooc.CORBA.GIOPServerWorker.execute(GIOPServerWorker.java:258)
> > at
> >com.ooc.CORBA.GIOPServerWorkerThreaded.receiverRun(GIOPServer
> WorkerThreaded.
> >java:567)
> > at
> >com.ooc.CORBA.GIOPServerWorkerThreaded$ReceiverThread.run(GIO
> PServerWorkerTh
> >readed.java:52)
> Markus Buchhorn, ANU Internet Futures Project, | Ph:
> +61 2 61258810
> Markus.Buchhorn at anu.edu.au, mail: Bldg #108 - CS&IT |Fax:
> +61 2 61259805
> Australian National University, Canberra 0200, Aust.
> |Mobile: 0417 281429
