[AG-TECH] ARM & VRM Corba errors
Randy Groves
randy.groves at boeing.com
Tue Jan 28 14:35:46 CST 2003
What's in the ag-dep package (if anything?). That's the only one that
doesn't seem to do anything. I've left it sit for about 10 minutes, but
get no output at all. Am I just not waiting long enough?
-randy
At 08:23 PM 1/27/2003 -0600, Ivan R. Judson wrote:
>Hey Markhus,
>You can check cvs -d:pserver:anonymous at ag-cvs.mcs.anl.gov:/cvsroot to see if
>there's anything newer.
>The modules to check out would be:
>AG
>ag-dep
>ag-linux-dep
>ag-src
>ag-vic
>ag-windows-dep
>dppt
>VV
>We'll be working to unify these together into the AG module as we have time.
>More importantly we'll be focusing on getting AG 2 ready for the alpha
>(coming to a town hall soon, bum bum bum).
>--Ivan
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Markus Buchhorn
> > Sent: Monday, January 27, 2003 7:35 PM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] ARM & VRM Corba errors
> > G'day y'all
> > We're just bringing up our first full node, using RH8.0 on
> > the audio/video machines. We're getting an error when
> > starting the eventlistener, the same as Tom Coffin mentioned
> > two years back :-)
> > http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/200
> > 1/01/msg00027.html (see below).
> > Following Bob's comments in the archives:
> > - Our RPMs are from that obscure snapshot directory of Bob's
> > (number 006 - which apparently is the latest?).
> > - I checked the A/Vrm-eventlistener scripts, which pointed
> > to the older jdk (117) java. Pointing them to the "newer"
> > (jre122) java only helped in the sense that it no longer
> > opened the OBnnnnn.jar files at all and complained about 'no
> > such method's :-)
> > - We get the same error regardless of whether the
> > event-monitor is running on the display machine or not, go figure.
> > - the display machine is running the 1.2 agdisplay bundle.
> > (The JRE java seems a bit odd in the way it opens noncore jar files?)
> > Any suggestions greatly appreciated. Is there anything newer
> > in the CVS areas? Or are there any rpm's we've missed? (I'd
> > expect different errors in that case).
> > Bring on 2.0 Ivan! :-)
> > Cheers,
> > Markus
> > >[root at ag1-audio root]# arm-eventlistener
> > >Didn't find name service: org.omg.CORBA.ORBPackage.InvalidName
> > >Got event channel
> > >org.omg.CosEventChannelAdmin.StubForEventChannel at 80c77d3
> > >Got ANY type 16
> > >channel listener caught org.omg.CORBA.BAD_OPERATION:
> > > at ag.MediaEventHelper.extract(MediaEventHelper.java:37)
> > > at ag.SdpChannelListener.push(SdpChannelListener.java:88)
> > > at
> > >org.omg.CosEventComm._PushConsumerImplBase._OB_op_push(_PushC
> > onsumerImplBase
> > >.java:41)
> > > at
> > >org.omg.CosEventComm._PushConsumerImplBase.invoke(_PushConsum
>erImplBase.java
> > >:109)
> > > at com.ooc.CORBA.BOA._OB_dispatch(BOA.java:1301)
> > > at
> > >com.ooc.CORBA.GIOPServerWorker.dispatchRequest(GIOPServerWork
> > er.java:417)
> > > at
> > >com.ooc.CORBA.GIOPServerWorkerThreaded.dispatchRequest(GIOPSe
> > rverWorkerThrea
> > >ded.java:317)
> > > at
> > com.ooc.CORBA.GIOPServerWorker.execute(GIOPServerWorker.java:258)
> > > at
> > >com.ooc.CORBA.GIOPServerWorkerThreaded.receiverRun(GIOPServer
> > WorkerThreaded.
> > >java:567)
> > > at
> > >com.ooc.CORBA.GIOPServerWorkerThreaded$ReceiverThread.run(GIO
> > PServerWorkerTh
> > >readed.java:52)
> > Markus Buchhorn, ANU Internet Futures Project, | Ph:
> > +61 2 61258810
> > Markus.Buchhorn at anu.edu.au, mail: Bldg #108 - CS&IT |Fax:
> > +61 2 61259805
> > Australian National University, Canberra 0200, Aust.
> > |Mobile: 0417 281429
