[AG-TECH] newer RedHat required. (fwd)
Randy Groves
randy.groves at boeing.com
Thu Jan 9 14:21:20 CST 2003
7.3 also works - don't know about 8.0 yet.
-randy
At 02:43 PM 1/9/2003 -0500, Andrew Bolyea wrote:
>Forgot to send this to ag-tech the first time.
>-------- Original Message --------
>Subject: Re: [AG-TECH] newer RedHat required
>Date: Thu, 09 Jan 2003 12:09:39 -0500
>From: Andrew Bolyea <andrew.bolyea at sheridanc.on.ca>
>To: Andrew Shewmaker <shewa at inel.gov>
>References: <20030109082155.42191db9.shewa at inel.gov>
>Hi Andrew.
>Quite some time ago I had to install RedHat 7.2 because 6.2 did not
>support some new hardware. Then I installed all the RPMs required for the
>AG (and everything seemed to work fine) :
>ag-bttv-0.6.4h-2.i386.rpm
>ag-install-1.0-5.i386.rpm
>ag-scripts-1.0-3.i386.rpm
>ag-vrm-1.06-1.i386.rpm
>java-getopt-1.0.6-1.i386.rpm
>job-3.3.2-1.i386.rpm
>jre-1.2.2-4.i386.rpm
>nlanr-beacon-0.63-1.i386.rpm
>opensound-3.9.4g-1.i386.rpm
>rtpmon-1.0a7-1.i386.rpm
>ucl-nte-1.7.0-1.i386.rpm
>ucl-rat-4.2.16-2.i386.rpm
>ucl-rat-debug-4.2.16-2.i386.rpm
>ucl-reflector-1.00-1.i386.rpm
>ucl-sdr-2.6.3-1.i386.rpm
>ucl-vic-2.8ucl1.1.3-5.i386.rpm
>vtc-1.00-1.i386.rpm
>xerces-j-1.1.3-1.i386.rpm
>There may be more recent versions of these packages.
>You may want to look at the following scripts, although again, I am not
>sure how current they are:
>http://ag-tech.mcs.anl.gov/reldb/repository/releases/agib/snapshots/snap-006/update
>http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/RPMS/update
>I hope this helps,
>Andrew.
>Andrew Bolyea
>Sheridan College
>Andrew Shewmaker` wrote:
>>Hello,
>>I am not allowed to use RedHat 6.2 due to security concerns, so I am
>>wondering if anybody has made packages for RedHat 7.x or 8?
>>Thanks,
>>Andrew
