[AG-TECH] newer RedHat required. (fwd)
Andrew Bolyea
andrew.bolyea at sheridanc.on.ca
Thu Jan 9 13:43:35 CST 2003
Forgot to send this to ag-tech the first time.
-------- Original Message --------
Subject: Re: [AG-TECH] newer RedHat required
Date: Thu, 09 Jan 2003 12:09:39 -0500
From: Andrew Bolyea <andrew.bolyea at sheridanc.on.ca>
To: Andrew Shewmaker <shewa at inel.gov>
References: <20030109082155.42191db9.shewa at inel.gov>
Hi Andrew.
Quite some time ago I had to install RedHat 7.2 because 6.2 did not
support some new hardware. Then I installed all the RPMs required for
the AG (and everything seemed to work fine) :
ag-bttv-0.6.4h-2.i386.rpm
ag-install-1.0-5.i386.rpm
ag-scripts-1.0-3.i386.rpm
ag-vrm-1.06-1.i386.rpm
java-getopt-1.0.6-1.i386.rpm
job-3.3.2-1.i386.rpm
jre-1.2.2-4.i386.rpm
nlanr-beacon-0.63-1.i386.rpm
opensound-3.9.4g-1.i386.rpm
rtpmon-1.0a7-1.i386.rpm
ucl-nte-1.7.0-1.i386.rpm
ucl-rat-4.2.16-2.i386.rpm
ucl-rat-debug-4.2.16-2.i386.rpm
ucl-reflector-1.00-1.i386.rpm
ucl-sdr-2.6.3-1.i386.rpm
ucl-vic-2.8ucl1.1.3-5.i386.rpm
vtc-1.00-1.i386.rpm
xerces-j-1.1.3-1.i386.rpm
There may be more recent versions of these packages.
You may want to look at the following scripts, although again, I am not
sure how current they are:
http://ag-tech.mcs.anl.gov/reldb/repository/releases/agib/snapshots/snap-006/update
http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/RPMS/update
I hope this helps,
Andrew.
Andrew Bolyea
Sheridan College
Andrew Shewmaker` wrote:
>Hello,
>I am not allowed to use RedHat 6.2 due to security concerns, so I am
>wondering if anybody has made packages for RedHat 7.x or 8?
>Thanks,
>Andrew
