[AG-TECH] adding a service; was: WinGlobus cert problem
Ivan R. Judson
judson at mcs.anl.gov
Fri Feb 28 06:16:34 CST 2003
Hey randy, I'm typing with one hand so excuse my poor formatting. Your cert
is issued by the ncsa ca, it looks like. That isn't known by our stuff.
Currently we only know about the globus ca and our ag developers ca. you
should grab a new cert from one of those and see if things work better.
I'd recommend the ag dev ca so you can fiddle with it. BUT, before you do
that if you can send me any and all output from running the agtk with your
ncsa cert that would be great...it should have at least reported the problem
in a more clear way.
--ivan
> -----Original Message-----
> From: Randy Heiland [mailto:heiland at ncsa.uiuc.edu]
> Sent: Friday, February 28, 2003 5:32 AM
> To: judson at mcs.anl.gov; 'Randy Heiland'; 'Thomas Uram'
> Cc: 'AG Tech'
> Subject: Re: [AG-TECH] adding a service; was: WinGlobus cert problem
> Thanks Ivan, maybe I'll learn something by remotedly
> attending your GGF tutorial, or reading whatever docs will
> evolve from that.
> Til then, I got to thinking about my grid certs and wondering
> if they are somehow invalid for doing all this AGTk stuff.
> My certs are probably 2 years old now, here's my ID:
> % grid-proxy-init -debug
> Files being used:
> cert_file: none
> cert_dir : /etc/grid-security/certificates
> proxy : /tmp/x509up_u23470
> user_cert: /home/heiland/.globus/usercert.pem
> user_key : /home/heiland/.globus/userkey.pem
> Your identity: /C=US/O=National Computational Science
> Alliance/CN=Randy Heiland Enter GRID pass phrase for this identity:
> Is there something unique about AGTk certs vs. Globus certs
> from ~2 yrs ago?
> fyi - I download all the AGTk s/w to my home WinXP system
> last night, ftp'd over my certs, but got to the same stopping
> point as already reported.
> I'm going off to read some AGTk security-related code now... :)
> --Randy
> On Feb 27, 6:57pm, Ivan R. Judson wrote:
> > Subject: RE: [AG-TECH] adding a service; was: WinGlobus cert problem
> > Randy,
> > I'm jumping in a bit late here, but I'm glad to see you are trying
> > this stuff. The documents you are looking for we are
> currently in the
> > middle of writing. The Tutorial for GGF7 is going to cover writing
> > the various types of services that can integrate
> applications support.
> > We're going to actually build a basic shared web browser
> and a basic
> > distributed powerpoint viewer to show how two kinds of apps can be
> > built. We're also going to build some trivial Node Service
> to show how
> > to extend the capabilities of a Node.
> > We'll be covering some of this same material (the more technical
> > stuff) at the AG Retreat in the Developers track. In
> between, I'd be
> > happy to chat with you and figure out if we can get you
> jump started
> > on building some simple apps that you can explore this
> territory with.
> > Sorry it took so long to get to this email, we're currently writing
> > the tutorial and the code to give at GGF --
> > Cheers,
> > --Ivan
> > > From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov]
> > > On Behalf Of Randy Heiland
> > > Sent: Thursday, February 27, 2003 3:35 PM
> > > To: Thomas Uram
> > > Cc: AG Tech
> cert problem
> > > Following Tom's doc (thanks), I get to the point of:
> > > --- on Win2K ---
> > > Start -> run Node Mgr
> > > File -> Attach to Node (enter
> > > "https://<myhost:11000/NodeService")
> > > get an error in(l.467 in alpha3.1):
> > > self.serviceManagers = self.vc.GetServiceManagers() saying,
> > > NoneType obj has no attr GetServiceManagers, so
> apparently vc isn't
> > > getting created properly. Guess I could do some
> debugging...but...
> > > --- returning to Linux ---
> > > I can run:
> > > % python NodeManagement.py
> > > and see 'localhost:12000' appear in the ServiceMgrs
> column. Also,
> > > the "- Connected" suffix appears in the frame's titlebar.
> > > But then what? What does "start adding services" (from the
> > > writeup) mean? Again, I'm new to the AG/AGTk landscape, so be
> > > gentle...
> > > Basically, I'd like to know how to "add a custom service
> that does
> > > X".
> > > Any pointers to docs, AGTk classes, etc, is welcome.
> > > thanks,
> > > --Randy
> > > On Feb 27, 10:35am, Thomas Uram wrote:
> > > > Subject: Re: [AG-TECH] WinGlobus cert problem
> > > > Randy:
> > > > You can find the "getting started" doc here:
> > > > http://scv.bu.edu/~jtvh/AGTk2/alpha02-getting-started.txt
> > > > Tom
> >-- End of excerpt from Ivan R. Judson
