[AG-TECH] adding a service; was: WinGlobus cert problem
Randy Heiland
heiland at ncsa.uiuc.edu
Fri Feb 28 05:31:56 CST 2003
Thanks Ivan, maybe I'll learn something by remotedly attending your GGF
tutorial, or reading whatever docs will evolve from that.
Til then, I got to thinking about my grid certs and wondering if they are
somehow invalid for doing all this AGTk stuff. My certs are probably 2 years
old now, here's my ID:
% grid-proxy-init -debug
Files being used:
cert_file: none
cert_dir : /etc/grid-security/certificates
proxy : /tmp/x509up_u23470
user_cert: /home/heiland/.globus/usercert.pem
user_key : /home/heiland/.globus/userkey.pem
Your identity: /C=US/O=National Computational Science Alliance/CN=Randy Heiland
Enter GRID pass phrase for this identity:
Is there something unique about AGTk certs vs. Globus certs from ~2 yrs ago?
fyi - I download all the AGTk s/w to my home WinXP system last night, ftp'd
over my certs, but got to the same stopping point as already reported.
I'm going off to read some AGTk security-related code now... :)
--Randy
On Feb 27, 6:57pm, Ivan R. Judson wrote:
> Subject: RE: [AG-TECH] adding a service; was: WinGlobus cert problem
> Randy,
> I'm jumping in a bit late here, but I'm glad to see you are trying this
> stuff. The documents you are looking for we are currently in the middle of
> writing. The Tutorial for GGF7 is going to cover writing the various types
> of services that can integrate applications support. We're going to
> actually build a basic shared web browser and a basic distributed powerpoint
> viewer to show how two kinds of apps can be built. We're also going to build
> some trivial Node Service to show how to extend the capabilities of a Node.
> We'll be covering some of this same material (the more technical stuff) at
> the AG Retreat in the Developers track. In between, I'd be happy to chat
> with you and figure out if we can get you jump started on building some
> simple apps that you can explore this territory with.
> Sorry it took so long to get to this email, we're currently writing the
> tutorial and the code to give at GGF --
> Cheers,
> --Ivan
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Randy Heiland
> > Sent: Thursday, February 27, 2003 3:35 PM
> > To: Thomas Uram
> > Cc: AG Tech
> > Subject: Re: [AG-TECH] adding a service; was: WinGlobus cert problem
> > Following Tom's doc (thanks), I get to the point of:
> > --- on Win2K ---
> > Start -> run Node Mgr
> > File -> Attach to Node (enter "https://<myhost:11000/NodeService")
> > get an error in(l.467 in alpha3.1):
> > self.serviceManagers = self.vc.GetServiceManagers()
> > saying, NoneType obj has no attr GetServiceManagers, so
> > apparently vc isn't getting created properly. Guess I could
> > do some debugging...but...
> > --- returning to Linux ---
> > I can run:
> > % python NodeManagement.py
> > and see 'localhost:12000' appear in the ServiceMgrs column.
> > Also, the "- Connected" suffix appears in the frame's titlebar.
> > But then what? What does "start adding services" (from the
> > writeup) mean? Again, I'm new to the AG/AGTk landscape, so
> > be gentle...
> > Basically, I'd like to know how to "add a custom service that does X".
> > Any pointers to docs, AGTk classes, etc, is welcome.
> > thanks,
> > --Randy
> > On Feb 27, 10:35am, Thomas Uram wrote:
> > > Subject: Re: [AG-TECH] WinGlobus cert problem
> > > Randy:
> > > You can find the "getting started" doc here:
> > > http://scv.bu.edu/~jtvh/AGTk2/alpha02-getting-started.txt
> > > Tom
>-- End of excerpt from Ivan R. Judson
