[AG-TECH] adding a service; was: WinGlobus cert problem
Ivan R. Judson
judson at mcs.anl.gov
Thu Feb 27 18:57:13 CST 2003
Randy,
I'm jumping in a bit late here, but I'm glad to see you are trying this
stuff. The documents you are looking for we are currently in the middle of
writing. The Tutorial for GGF7 is going to cover writing the various types
of services that can integrate applications support. We're going to
actually build a basic shared web browser and a basic distributed powerpoint
viewer to show how two kinds of apps can be built. We're also going to build
some trivial Node Service to show how to extend the capabilities of a Node.
We'll be covering some of this same material (the more technical stuff) at
the AG Retreat in the Developers track. In between, I'd be happy to chat
with you and figure out if we can get you jump started on building some
simple apps that you can explore this territory with.
Sorry it took so long to get to this email, we're currently writing the
tutorial and the code to give at GGF --
Cheers,
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Randy Heiland
> Sent: Thursday, February 27, 2003 3:35 PM
> To: Thomas Uram
> Cc: AG Tech
> Subject: Re: [AG-TECH] adding a service; was: WinGlobus cert problem
> Following Tom's doc (thanks), I get to the point of:
> --- on Win2K ---
> Start -> run Node Mgr
> File -> Attach to Node (enter "https://<myhost:11000/NodeService")
> get an error in(l.467 in alpha3.1):
> self.serviceManagers = self.vc.GetServiceManagers()
> saying, NoneType obj has no attr GetServiceManagers, so
> apparently vc isn't getting created properly. Guess I could
> do some debugging...but...
> --- returning to Linux ---
> I can run:
> % python NodeManagement.py
> and see 'localhost:12000' appear in the ServiceMgrs column.
> Also, the "- Connected" suffix appears in the frame's titlebar.
> But then what? What does "start adding services" (from the
> writeup) mean? Again, I'm new to the AG/AGTk landscape, so
> be gentle...
> Basically, I'd like to know how to "add a custom service that does X".
> Any pointers to docs, AGTk classes, etc, is welcome.
> thanks,
> --Randy
> On Feb 27, 10:35am, Thomas Uram wrote:
> > Subject: Re: [AG-TECH] WinGlobus cert problem
> > Randy:
> > You can find the "getting started" doc here:
> > http://scv.bu.edu/~jtvh/AGTk2/alpha02-getting-started.txt
> > Tom
