[AG-TECH] adding a service; was: WinGlobus cert problem
Thomas Uram
turam at mcs.anl.gov
Thu Feb 27 16:35:36 CST 2003
Randy:
That's not my doc, that's Jennifer's. Thanks, Jennifer.
It looks like your proxy has expired on Windows. Renew the proxy and
you should get to the same place as you did on Linux.
To "start adding services", select a service manager from the list, and
use the Services menu item AddService. By doing this, you are choosing
which media types you want to send and receive. These should then
update when you enter a venue using the Venue Client.
Tom
Randy Heiland wrote:
>Following Tom's doc (thanks), I get to the point of:
>--- on Win2K ---
>Start -> run Node Mgr
> File -> Attach to Node (enter "https://<myhost:11000/NodeService")
>get an error in(l.467 in alpha3.1):
> self.serviceManagers = self.vc.GetServiceManagers()
>saying, NoneType obj has no attr GetServiceManagers, so apparently vc isn't
>getting created properly. Guess I could do some debugging...but...
>--- returning to Linux ---
>I can run:
>% python NodeManagement.py
>and see 'localhost:12000' appear in the ServiceMgrs column. Also, the "-
>Connected" suffix appears in the frame's titlebar.
>But then what? What does "start adding services" (from the writeup) mean?
> Again, I'm new to the AG/AGTk landscape, so be gentle...
>Basically, I'd like to know how to "add a custom service that does X".
>Any pointers to docs, AGTk classes, etc, is welcome.
>thanks,
>--Randy
>On Feb 27, 10:35am, Thomas Uram wrote:
>>Subject: Re: [AG-TECH] WinGlobus cert problem
>>Randy:
>>You can find the "getting started" doc here:
>>http://scv.bu.edu/~jtvh/AGTk2/alpha02-getting-started.txt
>>Tom
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030227/b192837e/attachment.htm>
