[AG-TECH] adding a service; was: WinGlobus cert problem
Randy Heiland
heiland at ncsa.uiuc.edu
Thu Feb 27 15:34:32 CST 2003
Following Tom's doc (thanks), I get to the point of:
--- on Win2K ---
Start -> run Node Mgr
File -> Attach to Node (enter "https://<myhost:11000/NodeService")
get an error in(l.467 in alpha3.1):
self.serviceManagers = self.vc.GetServiceManagers()
saying, NoneType obj has no attr GetServiceManagers, so apparently vc isn't
getting created properly. Guess I could do some debugging...but...
--- returning to Linux ---
I can run:
% python NodeManagement.py
and see 'localhost:12000' appear in the ServiceMgrs column. Also, the "-
Connected" suffix appears in the frame's titlebar.
But then what? What does "start adding services" (from the writeup) mean?
Again, I'm new to the AG/AGTk landscape, so be gentle...
Basically, I'd like to know how to "add a custom service that does X".
Any pointers to docs, AGTk classes, etc, is welcome.
thanks,
--Randy
On Feb 27, 10:35am, Thomas Uram wrote:
> Subject: Re: [AG-TECH] WinGlobus cert problem
> Randy:
> You can find the "getting started" doc here:
> http://scv.bu.edu/~jtvh/AGTk2/alpha02-getting-started.txt
> Tom
