[AG-TECH] WinGlobus cert problem
Shawn Davis
wdavis at ncsa.uiuc.edu
Thu Feb 27 07:37:42 CST 2003
At 06:45 AM 2/27/2003, Randy Heiland wrote:
>I then run 'Grid Proxy Init' -> Create, enter my passphrase (as I used on
>Linux), and get an error:
> 952:error...:proxy_local_create:Problems creating proxy
>file:.\gssapi_ssleay\sslutils.c:3088
> Open failed for File=c:...\heiland\LOCALS~1\Temp
>the "...heiland\Local Settings\Temp" dir does exist, but ???
For the proxy location, you need to specify a filename in addition to a
path. The file should not exist; you're simply specifying where it should
store the proxy data.
So something like "...heiland\Local Settings\Temp\proxy" would work.
-Shawn
