[AG-TECH] WinGlobus cert problem
Ti Leggett
leggett at mcs.anl.gov
Thu Feb 27 08:19:54 CST 2003
I really think the problem lies in something not being happy with the
truncated 8.3 paths with '~' in them. If you choose broswse and rechoose
just directory so it has the full path (eg, C:\Documents and
Setting....) it works. This stems from using %TEMP% which for some
reason truncates the paths.
On Thu, 2003-02-27 at 07:37, Shawn Davis wrote:
> At 06:45 AM 2/27/2003, Randy Heiland wrote:
> >I then run 'Grid Proxy Init' -> Create, enter my passphrase (as I used on
> >Linux), and get an error:
> > 952:error...:proxy_local_create:Problems creating proxy
> >file:.\gssapi_ssleay\sslutils.c:3088
> > Open failed for File=c:...\heiland\LOCALS~1\Temp
> >the "...heiland\Local Settings\Temp" dir does exist, but ???
> For the proxy location, you need to specify a filename in addition to a
> path. The file should not exist; you're simply specifying where it should
> store the proxy data.
> So something like "...heiland\Local Settings\Temp\proxy" would work.
> -Shawn
