[AG-TECH] WinGlobus cert problem
Randy Heiland
heiland at ncsa.uiuc.edu
Thu Feb 27 06:45:12 CST 2003
Failing to get AGTk running on my Linux box, I thought I'd give it a go on
Windows. I installed the prereq pkgs (ActiveState's Python, wxPython, logging
module) and then the winGlobus.exe . I then run the 'Windows Globus'->'Globus
Configuration' and get into the little Setup Wizard. Here lie my
questions/problems. It has the 4 pieces of "registry settings":
User cert file: ...\heiland\Application Data\.globus\usercert.pem
User key file: ...
Proxy cert file: ...
Trusted cert dir: ...
I copied (manually, using psftp) my usercert.pem and userkey.pem files from my
Linux box into the above ...\.globus dir.
I then run 'Grid Proxy Init' -> Create, enter my passphrase (as I used on
Linux), and get an error:
952:error...:proxy_local_create:Problems creating proxy
file:.\gssapi_ssleay\sslutils.c:3088
Open failed for File=c:...\heiland\LOCALS~1\Temp
the "...heiland\Local Settings\Temp" dir does exist, but ???
Can anyone offer any clues?
(Maybe I'll return to Linux-land :)
thanks,
--Randy
