[AG-TECH] Python installation problem
Ti Leggett
leggett at mcs.anl.gov
Thu Feb 6 09:03:34 CST 2003
Looking at the RH72 cds it seems that the python ditstributed is
python-1.5 and python-2.1. You'll need to upgrade I think. What you
downloaded from python was the source RPM (they allow you to build your
own RPMs). If you'd like to build python-2.2 from the source rpm do:
rpm --rebuild python2.2.2-2.2.2-1.src.rpm
That will build you own RPMs It'll print out where it writes the new
rpms at the end. It'll look something like:
Wrote: /usr/src/redhat/RPMS/i386/python2-2.2.2-1.i386.rpm
Just FYI, if you look in /usr/src/redhat/SPECS and
/usr/src/redhat/SOURCES you'll see the python2 spec file from that
source RPMS. That's because when you do an install (rpm -U) of a source
RPM (SRPM) it puts the source files in that directory (/usr/src/redhat).
Hope that helps somewhat.
On Thu, 2003-02-06 at 07:30, Michael Daw wrote:
> I seem to be falling at the first hurdle in my attempted installation of
> AG2.0.
> I'm trying to install Python 2.2. I'm running RH7.2 and I've downloaded the
> file python2.2.2-2.2.2-1.src.rpm from http://www.python.org/2.2.2/rpms.html
> (as instructed on
> http://www-unix.mcs.anl.gov/fl/research/accessgrid/status/software.html).
> When I run 'rpm -U python2.2.2-2.2.2-1.src.rpm', I get no messages.
> When I run 'rpm -V python2.2.2-2.2.2-1.src.rpm', I get 'package
> python2.2.2-2.2.2-1.src.rpm is not installed'.
> When I run 'rpm -vvU python2.2.2-2.2.2-1.src.rpm' (to output debug), I get:
> D: ============== python2.2.2-2.2.2-1.src.rpm
> D: Expected size: 6667399 = lead(96)+sigs(180)+pad(4)+data(6667119)
> D: Actual size: 6667399
> D: added source package [0]
> D: found 1 source and 0 binary packages
> python2.2.2-2.2.2-1
> D: ========= Directories not explictly included in package:
> D: 0 /usr/src/redhat/SOURCES/
> D: 1 /usr/src/redhat/SPECS/
> D: =========
> D: fini 100664 1 ( 0, 0) 6669400
> /usr/src/redhat/SOURCES/Python-2.2.2.tgz
> D: fini 100644 1 ( 0, 0) 10769
> /usr/src/redhat/SPECS/python-2.2.spec
> GZDIO: 816 reads, 6680552 total bytes in 0.096 secs
> I thought I'd check whether I'd already got Python 2.2 installed, but
> running 'python' at the command line gets:
> Python 1.5.2 (#1, Jul 5 2001, 03:02:19) [GCC 2.96 20000731 (Red Hat Linux
> 7.1 2 on linux-i386
> Copyright 1991-1995 Stichting Mathematisch Centrum, Amsterdam
> ...which I assume means I'm running v1.5.2.
> I've since gone down the track of downloading and making Python-2.2.tgz from
> http://www.python.org/2.2/, then linking the resulting executable to
> /usr/bin/python. Is this OK, or does the rpm do other things I should know
> about?!
> I guess either:
> 1. I'm doing something daft, in which case please enlighten me.
> 2. There are problems installing python using the rpm, in which case new
> instructions are needed on the AG web page.
> --Mike (about to embark on the second hurdle...)
> _______________________________________________________
> Michael Daw
> SVE Group (Supercomputing, Visualization and e-Science)
> Manchester Computing, Kilburn Building,
> University of Manchester, Manchester M13 9PL, UK
> Tel: +44 (0)161 275 7026
> Fax: +44 (0)161 275 6800
> Email: michael.daw at man.ac.uk
> http://www.sve.man.ac.uk/General/Staff/daw
Ti Leggett <leggett at mcs.anl.gov>
