[AG-TECH] Globus data management install problem?
Michael Daw
mike.daw at man.ac.uk
Thu Feb 6 08:32:20 CST 2003
You'll be glad to hear the next 3 hurdles were cleared without a hitch!
However, now I've got some worrying messages from the Globus Data Management
install. Namely, the following. (I've snipped the worrying messages from the
whole output, but I've also put the whole output below.) Should I stop
worrying?
#### Selected output begins ####
Running setup-ssl-utils-sh-scripts...
/usr/lib/globus/setup/globus/setup-ssl-utils-sh-scripts:
/usr/lib/globus/libexec/globus-sh-tools.sh: No such file or directory
chmod: getting attributes of
`/usr/lib/globus/setup/globus/grid-security-config': No such file or
directory
Failed to set permissions on
/usr/lib/globus/setup/globus/grid-security-config at
/usr/lib/globus/setup/globus/setup-ssl-utils.pl line 62.
#### Output ends ####
#### Full output begins ####
[root at george ag2.0]# rpm -ivh
globus-data-management-gcc32pthr-2.0-1.i386.rpm
Preparing... ###########################################
[100%]
1:globus-data-management-###########################################
[100%]
Creating new ./globus-postinstall-1044541191.sh . . .
setup-ssl-utils: Configuring ssl-utils package
directory
creating globus-script-initializer
creating globus-sh-tools.sh
creating globus-makefile-header
Done
Creating globus-hostname
Creating globus-domainname
Done
Creating new ./globus-postinstall-1044541193.sh . . .
Note: To complete setup of the GSI software you need to run the
following script as root to configure your /etc/grid-security/
directory:
/usr/lib/globus/setup/globus/setup-gsi
setup-ssl-utils: Complete
Press return to continue.
globus_ssl_utils_rtl requires trusted_ca_setup to be set up
You have a coherent development tree
No packages are missing from your install tree
You will need to run /usr/lib/globus/setup/globus/setup-gsi after
installation has completed
_______________________________________________________
Michael Daw
SVE Group (Supercomputing, Visualization and e-Science)
Manchester Computing, Kilburn Building,
University of Manchester, Manchester M13 9PL, UK
Tel: +44 (0)161 275 7026
Fax: +44 (0)161 275 6800
Email: michael.daw at man.ac.uk
http://www.sve.man.ac.uk/General/Staff/daw
