[AG-TECH] Globus data management install problem?
Ivan R. Judson
judson at mcs.anl.gov
Thu Feb 6 08:39:10 CST 2003
Hey Mike,
These are great things for us to hear, but it'd help a lot of you put these
in bugzilla so we can track them. Unfortunately we don't have a good way to
track feature requests or bug reports on ag-tech.
Thanks!
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Michael Daw
> Sent: Thursday, February 06, 2003 8:32 AM
> To: AG Technical Developers
> Subject: [AG-TECH] Globus data management install problem?
> You'll be glad to hear the next 3 hurdles were cleared
> without a hitch!
> However, now I've got some worrying messages from the Globus
> Data Management install. Namely, the following. (I've snipped
> the worrying messages from the whole output, but I've also
> put the whole output below.) Should I stop worrying?
> #### Selected output begins ####
> Running setup-ssl-utils-sh-scripts...
> /usr/lib/globus/setup/globus/setup-ssl-utils-sh-scripts:
> /usr/lib/globus/libexec/globus-sh-tools.sh: No such file or directory
> chmod: getting attributes of
> `/usr/lib/globus/setup/globus/grid-security-config': No such
> file or directory Failed to set permissions on
> /usr/lib/globus/setup/globus/grid-security-config at
> /usr/lib/globus/setup/globus/setup-ssl-utils.pl line 62. ####
> Output ends ####
> #### Full output begins ####
> [root at george ag2.0]# rpm -ivh
> globus-data-management-gcc32pthr-2.0-1.i386.rpm
> Preparing...
> [100%]
> 1:globus-data-management-###########################################
> [100%]
> Creating new ./globus-postinstall-1044541191.sh . . .
> setup-ssl-utils: Configuring ssl-utils package
> creating globus-script-initializer creating
> globus-sh-tools.sh creating globus-makefile-header Done
> Creating globus-hostname Creating globus-domainname Done
> Creating new ./globus-postinstall-1044541193.sh . . .
> Note: To complete setup of the GSI software you need to run
> the following script as root to configure your /etc/grid-security/
> directory:
> /usr/lib/globus/setup/globus/setup-gsi
> setup-ssl-utils: Complete
> Press return to continue.
> globus_ssl_utils_rtl requires trusted_ca_setup to be set up
> You have a coherent development tree
> No packages are missing from your install tree
> You will need to run /usr/lib/globus/setup/globus/setup-gsi
> after installation has completed
> #### Output ends ####
> _______________________________________________________
> Michael Daw
> SVE Group (Supercomputing, Visualization and e-Science)
> Manchester Computing, Kilburn Building,
> University of Manchester, Manchester M13 9PL, UK
> Tel: +44 (0)161 275 7026
> Fax: +44 (0)161 275 6800
> Email: michael.daw at man.ac.uk
http://www.sve.man.ac.uk/General/Staff/daw
