[AG-TECH] Single computer node and good projectors
Doug Bowman
bowman at mvoice.com
Thu Dec 11 11:45:24 CST 2003
We have NEC 1060's, which we operate at the econo setting, however even
at low output we only get about 12-14 months use out of a bulb and they
cost about $700 each. When we last replaced bulbs, we used an allocation
that allowed us to buy nine....
Aside from that we are very happy with the NEC projectors.
Doug Bowman
Director
Mediavoice Communications Inc.
http://www.mvoice.com
Stuart Levy wrote:
>>No bulb replacements?! Wow. Our Epsons require new bulbs about once a year.
>>Considering their expense (£300 / $500ish for each bulb), this is quite a
>>problem. Is it just the Epsons that need so many new bulbs or is it that we
>>just use them more than you...?
>Some projectors have lamp-output controls, so you can run them in
>less-bright-but-longer-life mode. Anybody use those?
>We have a pair of JVC G150CL's (not being used in an AG, but who cares)
>whose rated bulb life is 1000 hours in "normal" mode, and 1900 hours in
>"lamp output control" mode when set to minimum brightness,
>which is still quite bright.
> Stuart
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031211/8f468607/attachment.htm>
