[AG-TECH] VenueServer and certificates
Ivan R. Judson
judson at mcs.anl.gov
Wed Dec 3 23:39:00 CST 2003
Hi Jeremy,
Sorry it took so long to get back to you. The venue server will run with
your certificate, and if you don't have a valid proxy it will ask you for
your passphrase to generate one.
The drawback to this is that in the number of hours specified the server
will become unresponsive (since it's proxy is invalid).
The alternative is to run the server with a service certificate, which is
currently unsupported, but should become supported very soon.
--Ivan
PS - it doesn't matter if you move your certificate, in fact, ideally
everybody only needs *exactly one certificate* they can then move that and
use it everywhere.
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Jeremy Mann
> Sent: Monday, December 01, 2003 8:13 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] VenueServer and certificates
> I've been playing around with the AG2 VenueServer. Does it
> have to have its own certificate?
> Since I already had a certificate for my laptop, and since it
> was a holiday weekend, I just imported my certificate onto
> the other computer (AG2 venue server). VenueServer starts and
> I can add 'rooms' and data.
> When I try to connect with my laptop I get this:
> Traceback (most recent call last):
> File
> "/usr/lib/python2.2/site-packages/AccessGrid/VenueClient.py",
> line 466, in EnterVenue
> raise EnterVenueException("No reachable venue at given venue URL")
> EnterVenueException: No reachable venue at given venue URL
> 12/01/03 08:03:41 16384 AG.Types VenueClient.py:698 DEBUG
> bin.VenueClient::EnterVenue: Enter venue with url:
> https://venue.uthscsa.edu:8000/Venues/default
> 12/01/03
> 08:03:41 16384 AG.Types VenueClient.py:711 DEBUG warningString:
> This URL is an inside VLAN URL, so you won't be able to test
> it on the outside. I am just curious if having the same
> certificates on both machines are conflicting each other.
> Thanks!
> Jeremy Mann
> jeremy at biochem.uthscsa.edu
> University of Texas Health Science Center
> Bioinformatics Core Facility http://www.bioinformatics.uthscsa.edu
> Phone: (210) 567-2672
