[AG-TECH] VenueServer Problem , please help urgently
Himani Gandhi
csa02037 at cse.iitd.ernet.in
Mon Dec 1 18:56:16 CST 2003
HI Ivan ,
Thanks for the feedback .
Though I have been able to figure out myself , by browsing through the
code .
Meanwhile , for my Linux CA and Windows2k personal node setup . I have
been able to " hack " the certificates by creating them offline and
putting them at the required directories for the trusted CA certs and the
user ca cert .
NOW MY PROBLEM IS :
I am running the server on the as per the instructions at :
http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid
I am able to run : VenueServer.py
but when I run : VenueManagement.py
and type the URL of the VenueServer and try to connect the
VenueManagement to VenueServer,i encounter some problems which i fail to
understand. i would be grateful if some one could provide some insights.
When the VenueManagement tries to connect to the VenueServer, the
ioc.tcp_connect call in GSIHTTPConnection.connect fails. ( " Thas what i
made of the debugger dumps that I saw !")
the logs of the script in the debugger are as follows:
> /usr/lib/python2.2/site-packages/pyGlobus/io.py(660)connect()
-> ret, handle = ioc.tcp_connect(host, port, attr.get_handle())
(Pdb)
> /usr/lib/python2.2/site-packages/pyGlobus/io.py(1223)get_handle()
-> def get_handle(self):
(Pdb) s
> /usr/lib/python2.2/site-packages/pyGlobus/io.py(1224)get_handle()
-> return self._handle
(Pdb) s
--Return--
/usr/lib/python2.2/site-packages/pyGlobus/io.py(1224)get_handle()->'_d05b8908_p_globus_io_attr_t'
(Pdb)
> /usr/lib/python2.2/site-packages/pyGlobus/io.py(661)connect()
-> if not ret == 0:
(Pdb) p ret
-1
(Pdb) s
> /usr/lib/python2.2/site-packages/pyGlobus/io.py(662)connect()
-> ex = GSITCPSocketException(handle)
(Pdb) p handle
'authentication failed:\n Authentication Failed\n GSS status:
major:000a0000 minor: 00000000 t
oken: 00000000\n'
(Pdb) s
> /usr/lib/python2.2/site-packages/pyGlobus/io.py(663)connect()
-> raise ex
(Pdb)
GSITCPSocketException: <pyGlobus.io.... at 0x8a102e4>
-> raise ex
(Pdb) c
Unable to Connect to Server https://arbit.cse.iitd.ernet.in:8000/VenueServer
Is There some known bug OR some configuration problem ?
MOREOVER , when I click on the "CHECKPOINT" option , I get a error similar
to :
major:000a0000 minor: 00000000 token: 00000000\n'
Please help me I am in urgent need of some help !
Thanks
Regards
Himani
On Mon, 1 Dec 2003, Ivan R. Judson wrote:
> Date: Mon, 1 Dec 2003 08:23:15 -0600
> From: Ivan R. Judson <judson at mcs.anl.gov>
> To: 'Himani Gandhi' <csa02037 at cse.iitd.ernet.in>, ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] Certificates for simple CA
> Hi Himani,
> Currently the AGTk does not support making requests to a certificate
> authority other than the ag developers ca. You would need to request the
> certificate from that CA using whatever means are available (perhaps
> grid-cert-req if you have it setup, or the CA might have a request process
> outlined).
> We will consider steps necessary to make this possible in the future.
> Thanks,
> --Ivan
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Himani Gandhi
> > Sent: Saturday, November 29, 2003 7:03 AM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] Certificates for simple CA
> > HI all ,
> > I wish to generate certificate to be submitted to the simple CA ,
> > on another LINUX machine here . I have imported the Trusted
> > Cert file (.o)
> > and the signing policy file to the directory of trusted Certs.
> > What else is to be done to generate certificate requests for
> > a simple CA
> > and not the CA at Argonne ?
> > Regards
> > Himani Gandhi
