[AG-TECH] Initial problems with latest AG release - RH 7.3
Robert Olson
olson at mcs.anl.gov
Fri Aug 29 13:22:51 CDT 2003
>1. I noticed that after the installation and after the cert import if I
>did not log out of my current X session, it (Venue Client) did not work.
>The installation issue had to do with Globus variables not being set.
>The Cert import I am unsure of. After starting a new X session
>everything seemed to work ok. You might want to put a text blurb to
>restart your X session before starting the Venue client for the first
>time.
I suspect that the globus-env stuff that needs to be sourced isn't until
the X session is restarted.
>3. Initially I was using a Dell GX400 with onboard audio. For some
>reason, even if LINUX configured the sound correctly (its an Intel AC97
>i810) RAT does not detect it. If you go into the audio preferences its
>not available from the PIC list of hardware. I found a SBLive! which
>fixed my problem. This looks like a RAT issue.
Which audio drivers is your system using? I believe we've used rat on an
i810 (that's what my linux box at home has, and I'm pretty sure I've used
rat on there; that was with the opensound.com drivers).
>4. Once I got RAT going with the SBLive, the transmit volume even with
>it cranked all the way up is WAY too low. I don't even get 4 bars
>maximum when yelling into my microphone. I launched aumix and the
>Microphone levels are maxed out. Is there something I'm missing? Any
>help would be greatly appreciated!
Depending on the mic you have, you may have to turn on the mic boost
setting that I think the SBLive has (it's a +20dB boost). Exactly how to do
that depends on which drivers you're using.
--bob
