[AG-TECH] Initial problems with latest AG release - RH 7.3
    Douglas Baggett
    dbaggett at nsf.gov
    Fri Aug 29 13:41:39 CDT 2003
Thanks for the help! I'll look at the driver on Monday. It's whatever
came with 7.3 and was configured with sndconfig. I can't remember if its
ALSA or not. I'll see if I can dig up the +20 mic boost on the SBlive, I
suspect it's probably going to be an option in the emu10k module driver.
thanks!
-Doug B
p.s. any ideas on why vic has a max of 128 k/b sec when starting from
the venu client? I started it manually and the max was at over 3 Mb/s.
On Fri, 2003-08-29 at 14:22, Robert Olson wrote:
> >1. I noticed that after the installation and after the cert import if I
> >did not log out of my current X session, it (Venue Client) did not work.
> >The installation issue had to do with Globus variables not being set.
> >The Cert import I am unsure of. After starting a new X session
> >everything seemed to work ok. You might want to put a text blurb to
> >restart your X session before starting the Venue client for the first
> >time.
> I suspect that the globus-env stuff that needs to be sourced isn't until
> the X session is restarted.
> >3. Initially I was using a Dell GX400 with onboard audio. For some
> >reason, even if LINUX configured the sound correctly (its an Intel AC97
> >i810) RAT does not detect it. If you go into the audio preferences its
> >not available from the PIC list of hardware. I found a SBLive! which
> >fixed my problem. This looks like a RAT issue.
> Which audio drivers is your system using? I believe we've used rat on an
> i810 (that's what my linux box at home has, and I'm pretty sure I've used
> rat on there; that was with the opensound.com drivers).
> >4. Once I got RAT going with the SBLive, the transmit volume even with
> >it cranked all the way up is WAY too low. I don't even get 4 bars
> >maximum when yelling into my microphone. I launched aumix and the
> >Microphone levels are maxed out. Is there something I'm missing? Any
> >help would be greatly appreciated!
> Depending on the mic you have, you may have to turn on the mic boost
> setting that I think the SBLive has (it's a +20dB boost). Exactly how to do
> that depends on which drivers you're using.
> --bob
