[AG-TECH] AGTk 2.1.1a for windows
    Joe Reitzer
    joer at ncsa.uiuc.edu
    Wed Aug 27 17:03:10 CDT 2003
I too get the error when installing AGTK-2.1.1a.exe:
"An error occurred while trying to read the source file:
The source file "C:\WINNT\system32\msvcr70.dll" does not exist.
Click Retry to try again, Ignore to skip this file(not recommended), or
Abort to cancel installation."
Attempting Installation on a W2K machine.
I have downloaded twice and tried installing twice same error.
Joe Reitzer
TRECC
At 06:47 AM 8/27/2003 -0600, Cindy Sievers wrote:
>I get the same error.  I also get an error when I try to run the venue client
>"Application unable to determine location of AGServiceManager.  If you
>installed using a windows installer, this is due to a bug in the
>installer.  If you are running from a CVS checkout, check the value of
>AGTK_INSTALL environment variable."
>At 06:16 AM 8/27/2003 -0500, Randy Heiland wrote:
>>Sorry for my basic ignorance in Windows-land, but I never had a problem
>>with "the missing msvcr70.dll" when I installed 2.1.1 on XP.  So, now
>>when I try to install this 2.1.1a pkg, I get the error:
>>c:\windows\system32\msvcr70.dll
>>Unable to register the type library...
>>Do I simply disregard this and proceed?
>>thanks,
>>--Randy
>>On Tue, 2003-08-26 at 16:13, Ivan R. Judson wrote:
>> > We've put out a very minor update, that includes the missing msvcr70.dll
>> > that was needed by the windows installer. The new package is at
>> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.1.1/window
>> > s.html
>> > --Ivan
>> > PS -- Thanks to Sam Fulcomer for finding, fixing, and reporting this
>> > problem!
>Cindy Sievers           Los Alamos National Laboratory
>sievers at lanl.gov        Group CCS-1 MS B287
>tel:505.665.6602        Advanced Computing
>fax:505.665.4939        Los Alamos, NM 87544
