[AG-TECH] Is the Lobby active or inactive?
Michael Miller
mimiller at ncsa.uiuc.edu
Thu Aug 28 14:24:37 CDT 2003
Randy,
I've gotten into the habit of disabling audio/video before I connect to the
Venues Server. Then I can navigate more quickly to where I want to
be. After seeing who is in the participants list, I turn on audio as that
is the least obtrusive way to find out what's going on in the venue. If
all is clear then I turn on video and have a look.
Some sort of common courtesy practice like this would be very desirable.
Michael Miller
NCSA
At 02:10 PM 8/28/2003, Randy Groves wrote:
>With the advent of the new venue server and clients, I'm wondering what
>the function of the 'Lobby' should be - if, in fact, it needs to exist -
>at least as a place where audio and video are active. Until such time as
>the network services exist to throttle the communications, entering the
>venue could be problematic if you are using a low-bandwidth client, and
>you are suddenly bombarded with the streams from all the people who are
>'parked' in the lobby.
>Though it hasn't undergone real extensive testing (and probably won't now
>that 2.0 is out and looking good), my 1.x venue server doesn't have ANY
>streams in the lobby. This gives folks a way to 'stop and catch their
>breath' before plunging into the fray.
>I'm interested in people's thoughts on this. Of course, since it isn't
>presently possible to configure a room with NO streams allocated, the
>point is somewhat moot. But that's how I see us using the lobby.
>-randy
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
