[AG-TECH] AGTk 2.1.1a for windows
Cindy Sievers
sievers at lanl.gov
Wed Aug 27 07:47:11 CDT 2003
I get the same error. I also get an error when I try to run the venue client
"Application unable to determine location of AGServiceManager. If you
installed using a windows installer, this is due to a bug in the
installer. If you are running from a CVS checkout, check the value of
AGTK_INSTALL environment variable."
At 06:16 AM 8/27/2003 -0500, Randy Heiland wrote:
>Sorry for my basic ignorance in Windows-land, but I never had a problem
>with "the missing msvcr70.dll" when I installed 2.1.1 on XP. So, now
>when I try to install this 2.1.1a pkg, I get the error:
>c:\windows\system32\msvcr70.dll
>Unable to register the type library...
>Do I simply disregard this and proceed?
>thanks,
>--Randy
>On Tue, 2003-08-26 at 16:13, Ivan R. Judson wrote:
> > We've put out a very minor update, that includes the missing msvcr70.dll
> > that was needed by the windows installer. The new package is at
> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.1.1/window
> > s.html
> > --Ivan
> > PS -- Thanks to Sam Fulcomer for finding, fixing, and reporting this
> > problem!
Cindy Sievers Los Alamos National Laboratory
sievers at lanl.gov Group CCS-1 MS B287
tel:505.665.6602 Advanced Computing
fax:505.665.4939 Los Alamos, NM 87544
