[AG-TECH] beacon, vtc, multicast???
Bob Riddle
bdr at internet2.edu
Fri Aug 8 20:17:31 CDT 2003
well ... when the Detective began, host based firewalls were not
pervasive & the early goal was to pick ports that wouldn't normally be
used on a Win98 machine ... so we threw darts at the wall and decided
that the Detective would use the following ports:
6666
7777
8888
We're going to change this in the next "semi-release" to use well-known
ports (80, 21, etc.) to the Detective Server on Abilene which we hope
will pass thru "normal" host based firewalls. This will, we hope,
discourage end-users from turning off their host-based firewalls (and
thus generating more exposure to their machine).
Any & all advice will be appreciated - if you prefer you can email me or
email "detective at internet2.edu".
Gurcharan S. Khanna wrote:
>hi,
>could someone refresh my memory? doesn't the moo run over port
>7777 also? and wasn't that also a problem due to that port being
>blocked or squeezed because it was the napster port? (it was always
>extremely slow for us; i guess there's a proxy now or something?).
>seems like some other port number would be more useful in these
>filtered environments. why is 7777 the port of choice?
>-gurcharan
>--- You wrote:
>On Fri, Aug 08, 2003 at 01:06:26AM -0400, Gurcharan S. Khanna wrote:
>>hi,
>>not sure if there's a built-in tool in AG 2.0 but you can download a nice
>>little utility from detective.internet2.edu called internet detective. this
>>will test for multicast connectivity, connection to the Abilene network, and
>>bandwidth tests.
>Note, though, that the new version of the tool runs over port 7777, and so may
>get blocked by various P2P firewall rules.
Bob Riddle (bdr at internet2.edu) Technologist,Internet2
3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
Business Phone: 734.913.4257 Fax Number: 734.913.4255
"Opportunity is missed by most people because it is dressed in overalls and looks like work" Thomas Edison
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030808/521d0553/attachment.htm>
