[AG-TECH] electronic whiteboards
John Shalf
jshalf at lbl.gov
Wed Oct 23 16:38:46 CDT 2002
On Wednesday, October 23, 2002, at 02:14 PM, Jay Beavers wrote:
> Only true if you think the quality of the captured ink is the same
> between a Mimeo sonically located ink marker and a high quality
> digitizer using an active radio located pressure sensitive pen. Having
> compared them, I wouldn't categorize the two as equivalent.
> It's also very true that writing on the display surface so you can see
> what you're writing where you're writing it is very different than
> writing on a separate surface from where the ink is rendered. Wacom has
> a very nice combination LCD / active digitizer monitor, but its cost
> exceeds that of a Tablet PC that has 802.11b built in so you can move
> around while collaborating.
Again,
the stylus is different from the whiteboard application. I agree a
TablePC offers more accurate capture of drawing than a Mimeo or mouse,
but that's an interface technology and can be treated separately from
the issue of bundling some (any) whiteboard software with an AG that
supports collaborative sharing of digital ink.
So I'd love to use a handheld tablet to draw on my 'wb' application
rather than using a mouse or digital easel, but wasn't really my point.
-john
> Right,
> and graphics tablets as an input device are mostly independent of the
> whiteboard application itself. I can use a mouse to scribble on 'wb' or
> I can use my Wacom driver or I can use the e-beam mouse. So the input
> device (as a topic of discussion) is separate from the issue of the
> software infrastructure to share our scribbling...
> -john
> On Wednesday, October 23, 2002, at 10:54 AM, bernholdtde at ornl.gov
> wrote:
>> On Wed, 23 Oct 2002 08:46:08 -0700 Jay Beavers wrote:
>>> Writing on whiteboards with mice is a bit of an exercise in
>>> frustration,
>> But graphics tablets, which substitute for mice are easier (it still
>> takes some getting used to however) and can be had for $100-200 and
>> up. Tablet PCs would be better, but cost O(10x) more.
>> David E. Bernholdt | Email: bernholdtde at ornl.gov
>> Oak Ridge National Laboratory | Phone: +1 (865) 574 3147
>> http://www.csm.ornl.gov/~bernhold/ | Fax: +1 (865) 574 0680
