[AG-TECH] electronic whiteboards
Jay Beavers
jbeavers at microsoft.com
Wed Oct 23 16:14:23 CDT 2002
Only true if you think the quality of the captured ink is the same
between a Mimeo sonically located ink marker and a high quality
digitizer using an active radio located pressure sensitive pen. Having
compared them, I wouldn't categorize the two as equivalent.
It's also very true that writing on the display surface so you can see
what you're writing where you're writing it is very different than
writing on a separate surface from where the ink is rendered. Wacom has
a very nice combination LCD / active digitizer monitor, but its cost
exceeds that of a Tablet PC that has 802.11b built in so you can move
around while collaborating.
- jcb
-----Original Message-----
Sent: Wednesday, October 23, 2002 12:55 PM
To: bernholdtde at ornl.gov
Cc: Jay Beavers; Osland, CD (Chris) ; ag-tech at mcs.anl.gov
Right,
and graphics tablets as an input device are mostly independent of the
whiteboard application itself. I can use a mouse to scribble on 'wb' or
I can use my Wacom driver or I can use the e-beam mouse. So the input
device (as a topic of discussion) is separate from the issue of the
software infrastructure to share our scribbling...
-john
On Wednesday, October 23, 2002, at 10:54 AM, bernholdtde at ornl.gov
wrote:
> On Wed, 23 Oct 2002 08:46:08 -0700 Jay Beavers wrote:
>> Writing on whiteboards with mice is a bit of an exercise in
>> frustration,
> But graphics tablets, which substitute for mice are easier (it still
> takes some getting used to however) and can be had for $100-200 and
> up. Tablet PCs would be better, but cost O(10x) more.
> David E. Bernholdt | Email: bernholdtde at ornl.gov
> Oak Ridge National Laboratory | Phone: +1 (865) 574 3147
> http://www.csm.ornl.gov/~bernhold/ | Fax: +1 (865) 574 0680
