[AG-TECH] Ports used in AG
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Fri Oct 18 04:53:35 CDT 2002
This would be invaluable as core documentation. We didn't have
any problems with VIC and RAT ports, but things like VNC caused
us great grief - I think in the end we found that it uses 5700 +
the screen number of the application, but I'd have to check.
Cheers
Chris Osland
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and
are for the use of the intended recipient only.
If you are not the intended recipient do not take
any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: Randy Groves [mailto:randy.groves at boeing.com]
Sent: 17 October 2002 23:02
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Ports used in AG
I'm faced with having to detail the ports used in AG work to our network
folks who have decided that our present external connection, which is
getting upgraded, needs a port filter applied. I BELIEVE, but I haven't
verified, that this box is smart enough that we don't have to detail all
the ports from which we will be originating transmissions, but incoming
ports that don't correspond to outgoing ports are an unknown for me. Is
there a document, or some collected wisdom, that I can tap?
Unfortunately, I don't think that 'leave all the ports open' is going to
be accepted as a valid answer.
Thanks!!
-randy
