[AG-TECH] Ports used in AG
Jennifer Teig von Hoffman
jtvh at bu.edu
Fri Oct 18 09:28:28 CDT 2002
A doc like this has been on the AGDP wish list for some time; I'd be
really happy to see somebody write it and submit it to us for
review/publication.
- Jennifer
Osland, CD (Chris) wrote:
> This would be invaluable as core documentation. We didn't have
> any problems with VIC and RAT ports, but things like VNC caused
> us great grief - I think in the end we found that it uses 5700 +
> the screen number of the application, but I'd have to check.
> Cheers
> Chris Osland
> ____________________________________________________________________
> Chris Osland Office tel: +44 (0) 1235 446565
> Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
> BIT Department Access Grid room tel: +44 (0) 1235 445666
> e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
> CLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and
> are for the use of the intended recipient only.
> If you are not the intended recipient do not take
> any action on it or show it to anyone else,
> but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: Randy Groves [mailto:randy.groves at boeing.com]
> Sent: 17 October 2002 23:02
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Ports used in AG
> I'm faced with having to detail the ports used in AG work to our network
> folks who have decided that our present external connection, which is
> getting upgraded, needs a port filter applied. I BELIEVE, but I haven't
> verified, that this box is smart enough that we don't have to detail all
> the ports from which we will be originating transmissions, but incoming
> ports that don't correspond to outgoing ports are an unknown for me. Is
> there a document, or some collected wisdom, that I can tap?
> Unfortunately, I don't think that 'leave all the ports open' is going to
> be accepted as a valid answer.
> Thanks!!
> -randy
