[AG-TECH] arm-eventlistener exception
Robert Olson
olson at mcs.anl.gov
Tue May 28 07:17:00 CDT 2002
At 06:21 PM 5/28/2002 +0800, kevin dong wrote:
> I have installed AG audio software on our audio computer and it works
> well when I execute the command "arm-eventlistener". But the error occurs
> when I click the "start audio capture" button. (The virtual room address
> is 233.2.171.39/42000. ) The printed information is
>"Exec audio:
> /usr/local/ag/bin/rat -f L16-16K-Mono -t 127 -C null 233.2.171.39/42000
> Process startup failure java.lang.NullPointerException. " and no rat
> frame appears!
>Looking forward to your help! Thank you! :)
Did you use the AG software on your display machine to get to the Test
Room, or did you enter the address manually? It is odd that there is a
"null" in that command line - the -C option specifies the conference name,
and the software should have filled in the name of the venue there.
--bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020528/7e02023a/attachment-0001.htm>
