[AG-TECH] arm-eventlistener exception
    Ivan R. Judson
    judson at mcs.anl.gov
    Tue May 28 06:12:32 CDT 2002
Hi Kevin,
Have you tried to execute that command by hand in a terminal or shell
window to see what the result it?
--Ivan
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of kevin dong
Sent: Tuesday, May 28, 2002 5:22 AM
To: ag-tech at accessgrid.org
Subject: [AG-TECH] arm-eventlistener exception
  I have installed AG audio software on our audio computer and it works
well when I execute the command "arm-eventlistener". But the error
occurs when I click the "start audio capture" button. (The virtual room
address is 233.2.171.39/42000. ) The printed information is "Exec audio:
  /usr/local/ag/bin/rat -f L16-16K-Mono -t 127 -C null
233.2.171.39/42000  Process startup failure
java.lang.NullPointerException.  "  and no rat frame appears!
Looking forward to your help! Thank you! :)
kevin dong
2002-05-28
Database Dept.
Computer Network Info Center,CAS
Tel: 0086-10-62580066
Fax: 0086-10-62578544 Email:kevin_dong2000 at yahoo.com,kevindong at sdb.ac.cn
