[AG-TECH] using vic to send normal graphics
    Chris Greenhalgh
    cmg at Cs.Nott.AC.UK
    Fri Mar 15 06:02:10 CST 2002
I'm sure some people are doing this already but...
I wanted to use VIC to stream from an OpenGL window (in s/w, no scan
convert/video in) and created a simple pseudo-frame grabber (attached if
anyone wants to play with it) that just calls a callback for you to fill
in the data to send; compile it into vic and the static instance
bootstraps its addition to the device list.
When using this I also found that on my machine (win2K, geforce2
graphics card) doing glGetPixels off the (default) front buffer actually
pulls in whatever is on the screen, so moving any application on top of
my GL window causes it to grab that window's pixels (and so send them
using the modified vic); may be easier than a vic grabber which is a vnc
client for sharing desktop apps?! (but i don't know how many cards will
exhibit this behaviour)
At some point I want to go the other way as well (i.e. take the incoming
video streams and use them to update GL textures); has anyone done this
already?
Cheers,
Chris
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020315/d267521b/attachment-0001.diff>
