[AG-TECH] NTP Questions
Bob Olson
olson at mcs.anl.gov
Fri Jul 12 11:25:31 CDT 2002
if you create a file /etc/ntp/step-tickers that contains the hostname of
the ntp server, it will time-synch to that server when the service starts
up.
--bob
On Fri, 12 Jul 2002, George Estes wrote:
> As I remember the time on your machine must be close, I don't remember
> how close, before the server will snyc. I know it will not sync if you
> machine clock is off by 10 minutes. On my machine, RedHat 7.1, I then run
> /usr/sbin/ntpdc -p my-machine-name and the delay should be less than .01.
> George
> At 04:19 PM 7/12/2002 +0100, you wrote:
> >I've got a couple of questions related to NTP. Bear with me, this is not a
> >short email...
> >I've built my audio and video capture machines manually (i.e. not AGiB).
> >That means that I installed all the bits separately. That also means that my
> >NTP wasn't nicely configured and "just working".
> >Don Morton helpfully told me what should go in my file /etc/ntp.conf:
> >server ntp-1.accessgrid.org
> >driftfile /etc/ntp/drift
> >I restarted ntpd afterwards.
> >My time stayed as it was (about 10 minutes wrong!). Do I have to wait to get
> >into synch? Maybe, but my settings don't look right anyway. (Read on...)
> >I've been scooting around some of the docs about ntp and tried running
> >ntpq - with 'pe', 'as' and 'rv'. I got this:
> >---------Start output
> >[root at audio root]# ntpq
> >ntpq> pe
> > remote refid st t when poll reach delay offset
> >jitter
> > ag.mcs.anl.gov 0.0.0.0 16 u - 64 0 0.000 0.000
> >4000.00
> >ntpq> as
> >ind assID status conf reach auth condition last_event cnt
> > 1 48124 8000 yes yes none reject
> >ntpq> rv 48124
> >status=8000 unreach, conf, no events,
> >srcadr=ag.mcs.anl.gov, srcport=123, dstadr=192.150.184.66, dstport=123,
> >leap=11, stratum=16, precision=-17, rootdelay=0.000,
> >rootdispersion=0.000, refid=0.0.0.0, reach=000, unreach=13, hmode=3,
> >pmode=0, hpoll=6, ppoll=10, flash=00 ok, keyid=0, offset=0.000,
> >delay=0.000, dispersion=0.000, jitter=4000.000,
> >reftime=00000000.00000000 Thu, Feb 7 2036 6:28:16.000,
> >org=00000000.00000000 Thu, Feb 7 2036 6:28:16.000,
> >rec=00000000.00000000 Thu, Feb 7 2036 6:28:16.000,
> >xmt=c0d96d24.d4832335 Fri, Jul 12 2002 15:58:44.830,
> >filtdelay= 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00,
> >filtoffset= 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00,
> >filtdisp= 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0
> >ntpq> quit
> >---------End output
> >Do I have a problem?
> >Second question. (Is anyone still with me, I wonder...) On my other machine,
> >I tried installing xntp. Possibly not a smart idea, but anyway.
> >Here, I got a different (possibly worse because I've got 'reach=no' rather
> >than 'auth=no'?) output:
> >root at video etc]# /usr/sbin/ntpq
> >ntpq> pe
> >disp
> > ag.mcs.anl.gov 0.0.0.0 16 u - 64 0 0.00 0.000
> >16000.0
> >ntpq> as
> > 1 37636 8000 yes no
> >ntpq> quit
> >---------End output
> >Help would be gratefully received...
> >Thanks,
> >Mike
> >-----------------------oOo-----------------------
> >Michael Daw
> >Computer Services for Academic Research (CSAR)
> >Manchester Computing, Kilburn Building,
> >University of Manchester, Manchester M13 9PL, UK
> >Tel: +44 (0)161 275 7026
> >Fax: +44 (0)161 275 6800
> >Email: michael.daw at man.ac.uk
> >http://www.csar.cfs.ac.uk/staff/daw/
> >-----------------------OoO-----------------------
