[AG-TECH] NTP Questions
George Estes
gestes at ncsa.uiuc.edu
Fri Jul 12 11:23:00 CDT 2002
As I remember the time on your machine must be close, I don't remember
how close, before the server will snyc. I know it will not sync if you
machine clock is off by 10 minutes. On my machine, RedHat 7.1, I then run
/usr/sbin/ntpdc -p my-machine-name and the delay should be less than .01.
George
At 04:19 PM 7/12/2002 +0100, you wrote:
>I've got a couple of questions related to NTP. Bear with me, this is not a
>short email...
>I've built my audio and video capture machines manually (i.e. not AGiB).
>That means that I installed all the bits separately. That also means that my
>NTP wasn't nicely configured and "just working".
>Don Morton helpfully told me what should go in my file /etc/ntp.conf:
>server ntp-1.accessgrid.org
>driftfile /etc/ntp/drift
>I restarted ntpd afterwards.
>My time stayed as it was (about 10 minutes wrong!). Do I have to wait to get
>into synch? Maybe, but my settings don't look right anyway. (Read on...)
>I've been scooting around some of the docs about ntp and tried running
>ntpq - with 'pe', 'as' and 'rv'. I got this:
>---------Start output
>[root at audio root]# ntpq
>ntpq> pe
> remote refid st t when poll reach delay offset
>jitter
> ag.mcs.anl.gov 0.0.0.0 16 u - 64 0 0.000 0.000
>4000.00
>ntpq> as
>ind assID status conf reach auth condition last_event cnt
> 1 48124 8000 yes yes none reject
>ntpq> rv 48124
>status=8000 unreach, conf, no events,
>srcadr=ag.mcs.anl.gov, srcport=123, dstadr=192.150.184.66, dstport=123,
>leap=11, stratum=16, precision=-17, rootdelay=0.000,
>rootdispersion=0.000, refid=0.0.0.0, reach=000, unreach=13, hmode=3,
>pmode=0, hpoll=6, ppoll=10, flash=00 ok, keyid=0, offset=0.000,
>delay=0.000, dispersion=0.000, jitter=4000.000,
>reftime=00000000.00000000 Thu, Feb 7 2036 6:28:16.000,
>org=00000000.00000000 Thu, Feb 7 2036 6:28:16.000,
>rec=00000000.00000000 Thu, Feb 7 2036 6:28:16.000,
>xmt=c0d96d24.d4832335 Fri, Jul 12 2002 15:58:44.830,
>filtdelay= 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00,
>filtoffset= 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00,
>filtdisp= 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0
>ntpq> quit
>---------End output
>Do I have a problem?
>Second question. (Is anyone still with me, I wonder...) On my other machine,
>I tried installing xntp. Possibly not a smart idea, but anyway.
>Here, I got a different (possibly worse because I've got 'reach=no' rather
>than 'auth=no'?) output:
>root at video etc]# /usr/sbin/ntpq
>ntpq> pe
>disp
> ag.mcs.anl.gov 0.0.0.0 16 u - 64 0 0.00 0.000
>16000.0
>ntpq> as
> 1 37636 8000 yes no
>ntpq> quit
>---------End output
>Help would be gratefully received...
>Thanks,
>Mike
>-----------------------oOo-----------------------
>Michael Daw
>Computer Services for Academic Research (CSAR)
>Manchester Computing, Kilburn Building,
>University of Manchester, Manchester M13 9PL, UK
>Tel: +44 (0)161 275 7026
>Fax: +44 (0)161 275 6800
>Email: michael.daw at man.ac.uk
>http://www.csar.cfs.ac.uk/staff/daw/
>-----------------------OoO-----------------------
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020712/4c604593/attachment.htm>
