[AG-TECH] NTP Questions
Thomas M. Mueller
thomas.m.mueller at Dartmouth.EDU
Fri Jul 12 10:24:52 CDT 2002
try using dateconfig for easy ntp setup.
On Fri, 2002-07-12 at 11:19, Mike Daw wrote:
> I've got a couple of questions related to NTP. Bear with me, this is not a
> short email...
> I've built my audio and video capture machines manually (i.e. not AGiB).
> That means that I installed all the bits separately. That also means that my
> NTP wasn't nicely configured and "just working".
> Don Morton helpfully told me what should go in my file /etc/ntp.conf:
> server ntp-1.accessgrid.org
> driftfile /etc/ntp/drift
> I restarted ntpd afterwards.
> My time stayed as it was (about 10 minutes wrong!). Do I have to wait to get
> into synch? Maybe, but my settings don't look right anyway. (Read on...)
> I've been scooting around some of the docs about ntp and tried running
> ntpq - with 'pe', 'as' and 'rv'. I got this:
> ---------Start output
> [root at audio root]# ntpq
> ntpq> pe
> remote refid st t when poll reach delay offset
> jitter
> ag.mcs.anl.gov 0.0.0.0 16 u - 64 0 0.000 0.000
> 4000.00
> ntpq> as
> ind assID status conf reach auth condition last_event cnt
> 1 48124 8000 yes yes none reject
> ntpq> rv 48124
> status=8000 unreach, conf, no events,
> srcadr=ag.mcs.anl.gov, srcport=123, dstadr=192.150.184.66, dstport=123,
> leap=11, stratum=16, precision=-17, rootdelay=0.000,
> rootdispersion=0.000, refid=0.0.0.0, reach=000, unreach=13, hmode=3,
> pmode=0, hpoll=6, ppoll=10, flash=00 ok, keyid=0, offset=0.000,
> delay=0.000, dispersion=0.000, jitter=4000.000,
> reftime=00000000.00000000 Thu, Feb 7 2036 6:28:16.000,
> org=00000000.00000000 Thu, Feb 7 2036 6:28:16.000,
> rec=00000000.00000000 Thu, Feb 7 2036 6:28:16.000,
> xmt=c0d96d24.d4832335 Fri, Jul 12 2002 15:58:44.830,
> filtdelay= 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00,
> filtoffset= 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00,
> filtdisp= 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0
> ntpq> quit
> ---------End output
> Do I have a problem?
> Second question. (Is anyone still with me, I wonder...) On my other machine,
> I tried installing xntp. Possibly not a smart idea, but anyway.
> Here, I got a different (possibly worse because I've got 'reach=no' rather
> than 'auth=no'?) output:
> root at video etc]# /usr/sbin/ntpq
> ntpq> pe
> disp
> ag.mcs.anl.gov 0.0.0.0 16 u - 64 0 0.00 0.000
> 16000.0
> ntpq> as
> 1 37636 8000 yes no
> ntpq> quit
> ---------End output
> Help would be gratefully received...
> Thanks,
> Mike
> -----------------------oOo-----------------------
> Michael Daw
> Computer Services for Academic Research (CSAR)
> Manchester Computing, Kilburn Building,
> University of Manchester, Manchester M13 9PL, UK
> Tel: +44 (0)161 275 7026
> Fax: +44 (0)161 275 6800
> Email: michael.daw at man.ac.uk
> http://www.csar.cfs.ac.uk/staff/daw/
> -----------------------OoO-----------------------
