[AG-TECH] Multicast service model
    Jon Crowcroft
    Jon.Crowcroft at cl.cam.ac.uk
    Wed Jan 23 01:44:09 CST 2002
In message <Pine.GSO.4.44.0201221611110.19264-100000 at darkwing.uoregon.edu>, "Lu
cy E. Lynch" typed:
 >>Since the access grid community are currently some of the most active
 >>users of Any Source Multicast service it might be useful for
 >>1] more folks to follow the mboned discussions
 >>http://www.ietf.cnri.reston.va.us/html.charters/mboned-charter.html
actualy, i follow both...
 >>2] those of us in two places at once to cross post (judiciously)
 >>   when issues of interest arise
ok - so note that the UK GRID is trying to run AG stuff over a net
which consists almost completely of MANs running PIM SM, a core
running PIM SM, connected by MSDP
boy oh boy is it hard to debug.
i wih we had bidir pim and bgmp...:-)
 >>thanks for getting this rolling -
 >>Lucy E. Lynch 				Academic User Services
 >>Computing Center			University of Oregon
 >>llynch at darkwing.uoregon.edu		(541) 346-1774/Cell: 912-7998
 >>On Tue, 22 Jan 2002, Bill Nickless wrote:
 >>> With the current discussion about multicast bridges, I think it might b=
 >>e
 >>> about the right time to show people this Internet Draft on the IP multi=
 >>cast
 >>> service model.
 >>> The closest thing we have in the Internet for a multicast service model
 >>> is  RFC 1112 by Steve Deering (1989).  It defines three things simultan=
 >>eously:
 >>>   - The multicast service model
 >>>   - The system call extensions needed on hosts to support those apps
 >>>     that want to take advantage of the multicast service model
 >>>   - (In Appendix A) the wire protocol to control multicast on
 >>>     the local subnet: IGMP
 >>> For the Access Grid, the service model is the most valuable of the
 >>> above.  The system call extension expectations are buried in the vic an=
 >>d
 >>> rat applications, so some programming effort would be required to move
 >>> beyond that.  The Access Grid applications have no particular need for =
 >>an
 >>> IGMP-based local wire protocol; in fact, the existing MSB doesn't use I=
 >>GMP
 >>> at all.
 >>> Caveats: the reference for the multicast service model on page 1 should
 >>>           be RFC 1112.
 >>>           David Helder suggested that we also look at the UDP Multicast
 >>>           Tunneling Protocol (UMTP) and Castgate.
 >>> Comments and criticism welcome.
 >>>     Internet Draft                                           B. Nickles=
 >>s
 >>>     Document: draft-nickless-mcast-svc-model-00.txt     Argonne Nationa=
 >>l
 >>>                                                               Laborator=
 >>y
 >>>     Expires: July 2002                                      January 200=
 >>2
 >>>                       Towards a Multicast Service Model
 >>> Status of this Memo
 >>>     This document is an Internet-Draft and is in full conformance
 >>>     with all provisions of Section 10 of RFC2026.
 >>>     Internet-Drafts are working documents of the Internet Engineering
 >>>     Task Force (IETF), its areas, and its working groups.  Note that
 >>>     other groups may also distribute working documents as Internet-
 >>>     Drafts.
 >>>     Internet-Drafts are draft documents valid for a maximum of six
 >>>     months and may be updated, replaced, or obsoleted by other document=
 >>s
 >>>     at any time.  It is inappropriate to use Internet-Drafts as
 >>>     reference material or to cite them other than as "work in progress.=
 >>>     The list of current Internet-Drafts can be accessed at
 >>>          http://www.ietf.org/ietf/1id-abstracts.txt
 >>>     The list of Internet-Draft Shadow Directories can be accessed at
 >>>          http://www.ietf.org/shadow.html.
 >>> Abstract
 >>>     This document outlines a framework for IP Multicast applications.
 >>>     It intends to describe the services that an application host and
 >>>     associated networks should provide, and provide a framework for
 >>>     evaluating ways to implement those services for applications.
 >>> Table of Contents
 >>>     Status of this Memo................................................=
 >>1
 >>>     Abstract...........................................................=
 >>1
 >>>     Conventions used in this document..................................=
 >>2
 >>>     Introduction and Motivation........................................=
 >>2
 >>>     Core Application Operations........................................=
 >>3
 >>>     Desirable Application Operations...................................=
 >>4
 >>>     Evaluation Framework...............................................=
 >>4
 >>>     Native Multicast (IGMP) Implementation of Core Operations..........=
 >>4
 >>>     SSM With Group Leader Implementation of Core Operations............=
 >>5
 >>>     PIM-speaking Host Implementation of Core Operations................=
 >>6
 >>>     Hypothetical TCP-based Tunnel Implementation of Core Operations....=
 >>6
 >>>     Nickless       Informational - Expires July 2002                 1
 >>>                    Towards A Multicast Service Model      January 2002
 >>>     Emcast Multicast Library...........................................=
 >>7
 >>>     Security Considerations............................................=
 >>8
 >>>     Acknowledgements...................................................=
 >>8
 >>>     References.........................................................=
 >>8
 >>>     Author's Address...................................................=
 >>8
 >>> Overview
 >>>     The traditional IP Multicast service model is conceptually simple: =
 >>a
 >>>     source application sends datagrams to the network, which delivers
 >>>     those datagrams to interested receiver applications.  Some
 >>>     applications could benefit from extensions to this conceptual model=
 >>>     such as providing the source application with knowledge of the
 >>>     existence of receivers.  There remain networks where IP Multicast
 >>>     deployment is not complete, requiring applications to work around
 >>>     the problem.  An application may wish to control which sources and
 >>>     receivers are permitted to participate.  The traditionally
 >>>     unreliable nature of IP Multicast datagram delivery requires
 >>>     applications to implement their own reliable delivery schemes.
 >>>     This Draft intends to describe an application framework that
 >>>     provides a unified multicast application service model.  Such a
 >>>     model could lead to a common Application Programming Interface for
 >>>     multicast applications.  It could also provide a framework for
 >>>     evaluating protocols and implementations.
 >>>     Criteria for evaluating implementations to support the application
 >>>     framework are supplied, along with a brief survey of some existing
 >>>     possible implementations.
 >>>     The key words "MUST", "MUST NOT", "REQUIRED", "SHALL", "SHALL NOT",
 >>>     "SHOULD", "SHOULD NOT", "RECOMMENDED", "MAY", and "OPTIONAL" in thi=
 >>s
 >>>     document are to be interpreted as described in RFC-2119 [RFC2119].
 >>>     IP Multicast [MCAST] is an internetwork service that allows IP
 >>>     datagrams sent from a source to be delivered to one or more
 >>>     interested receiver(s).  That is, a host system sends a packet to
 >>>     the internetwork with a multicast group destination address.  The
 >>>     internetwork transports this packet to all receivers (replicated
 >>>     where necessary) that have registered interest in receiving these
 >>>     packets.
 >>>     This multicast service model (XXX =96 needs reference) was derived
 >>>     from how an operating system interacts with an Ethernet network
 >>>     interface.  To send, the operating system builds Ethernet frames in
 >>>     Nickless       Informational - Expires July 2002                 2
 >>>     a buffer and hands that buffer off to the Ethernet interface for
 >>>     transmission.  To receive, an operating system programs the Etherne=
 >>t
 >>>     interface to accept frames that match a certain Media Access Contro=
 >>l
 >>>     (MAC) address.
 >>>     Several classes of multicast applications have evolved.  The first
 >>>     and perhaps best-known application is the multiparty multimedia
 >>>     conference.  Following close behind is the use of IP multicast for
 >>>     service discovery, such as how the Open Shortest Path First (OSPF)
 >>>     routing protocol discovers adjacent routers.  Distributing media
 >>>     content (for example, Internet Radio) is a natural fit for IP
 >>>     multicast.  Time-sensitive distribution of financial market
 >>>     information can also be done through IP multicast.  Parallel
 >>>     computations often require collective operations (barriers,
 >>>     broadcasts, multicasts) that could be implemented using IP multicas=
 >>t
 >>>     technology.  The distribution of files across clusters of computers
 >>>     is a natural use of reliable multicast protocols.
 >>>     Application developers and users have come to expect certain
 >>>     facilities to be available from an IP Multicast-enabled network.
 >>>     Often, when a local host or network does not support native IP
 >>>     Multicast, the application developer and/or end-user will implement
 >>>     these facilities independent of the network.
 >>>     Host Interface Discovery (INTERFACE DISCOVERY): The application
 >>>     queries the host to discover which, if any, of the host interfaces
 >>>     support IP Multicast services, and the IP address assigned to each
 >>>     interface.
 >>>     Multicast Packet Transmission (TRANSMIT): An application constructs
 >>>     an IP datagram including the IP Source Address determined through
 >>>     the INTERFACE DISCOVERY step and the IP Destination Address
 >>>     determined through the GROUP SELECT step.  A pointer to this
 >>>     datagram is conveyed to the host, which is then responsible for
 >>>     transmitting this datagram to the network for transport to
 >>>     interested receivers.
 >>>     Join Multicast Group (JOIN): An application notifies the host that
 >>>     it wishes to receive IP datagrams addressed to a given IP
 >>>     Destination/Group address.  Optionally, in the case of Source
 >>>     Specific Multicast, the application also notifies the host that it
 >>>     wishes to receive IP datagrams originated by a certain set of hosts
 >>>     identified by IP Source Addresses.  The host notifies the network t=
 >>o
 >>>     deliver such packets, and returns an opaque identifier to the
 >>>     application for later use.
 >>>     Multicast Packet Receipt (RECEIVE): An application provides a memor=
 >>y
 >>>     pointer to the host, along with an opaque identifier provided by th=
 >>e
 >>>     host in the JOIN operation.  The host waits until a datagram is
 >>>     received from the network that has an appropriate IP Destination
 >>>     Group address (and optionally an appropriate IP Source Address).
 >>>     Nickless       Informational - Expires July 2002                 3
 >>>     When received, the data is copied into memory associated with the
 >>>     pointer.
 >>>     Leave Multicast Group (LEAVE): An application notifies the host tha=
 >>t
 >>>     it no longer wishes to receive IP datagrams addressed to a given IP
 >>>     Destination and/or Group address.  The host in turn notifies the
 >>>     network to stop delivering such packets.
 >>>     In addition to the Core Application Operations listed above,
 >>>     application developers and users are requesting certain additional
 >>>     services.  At present these are not widely available or in use.
 >>>     Measure Group Size (GROUP SIZE): An application queries the host to
 >>>     determine whether there are any interested Receivers to which
 >>>     multicast datagrams might be delivered.  If the returned estimate i=
 >>s
 >>>     zero, the application might choose not to construct IP datagrams fo=
 >>r
 >>>     transmission.
 >>>     Authenticated Join Multicast Group (SECURE JOIN): An application
 >>>     must provide an authentication token as part of the JOIN operation.
 >>>     Authenticated Transmit To Multicast Group (SECURE TRANSMIT): An
 >>>     application must be "approved" in some way in order for its data to
 >>>     be received by cooperating receivers.
 >>>     As shown in the rest of this Draft, there are several possible ways
 >>>     of providing the multicast service to applications.  Criteria for
 >>>     evaluating each approach should include:
 >>>      - How expensive is the deployment of the approach?  Does it requir=
 >>e
 >>>        the cooperation of the local network administrator to operate?
 >>>      - Is it compatible with the Best Current Practices of routing IP
 >>>        multicast in the Internet core?
 >>>      - Does it ensure that only one copy of a multicast packet need
 >>>        traverse a network link?
 >>>      - Does it allow for both multicast transmission and reception?
 >>>     Each of the following approaches is evaluated by these criteria.
 >>>     The traditional IGMPv2 service model implements the core applicatio=
 >>n
 >>>     services in the following way:
 >>>     INTERFACE DISCOVERY is done by putting reachability information in
 >>>     the host reachability table, generally with a static route to the
 >>>     224.0.0.0/4 logical internet subnet.  The application looks up this
 >>>     reachability information and uses the IP address associated with th=
 >>e
 >>>     appropriate host interface.
 >>>     Nickless       Informational - Expires July 2002                 4
 >>>     TRANSMIT is done by the host executing the equivalent of a UNIX
 >>>     sendto() call, with the source address set by the INTERFACE
 >>>     DISCOVERY step above, and the destination address set to the
 >>>     intended Group address.
 >>>     JOIN is done through the operation of the IGMP protocol.  The
 >>>     application instructs the host to create IGMP Group Membership
 >>>     reports, which the network uses to create appropriate forwarding
 >>>     trees to the local subnetwork.
 >>>     RECEIVE is done by the host executing the equivalent of a UNIX
 >>>     recvfrom() call, with the from address set to the Group address.
 >>>     LEAVE is done through the operation of the IGMP protocol. The
 >>>     application instructs the host to stop issuing IGMP Group Membershi=
 >>p
 >>>     reports indicating interest in that Group.
 >>>     An extension of IGMP might support the SECURE JOIN Operation.
 >>>     Implementation of this approach requires that the host, and the hos=
 >>t
 >>>     network, be made IGMP-aware.  If properly configured by the network
 >>>     administrator, it is compatible with IPv4 routing Best Current
 >>>     Practices.  Only one copy of a multicast packet is sent or received
 >>>     by the local Designated Router.  Multicast transmission and
 >>>     reception is supported.
 >>>     Single Source Multicast is generally implemented by a combination o=
 >>f
 >>>     IGMPv3 between the host and the network, and source-specific-tree-
 >>>     only PIM operations.  Group addresses are in the 232.0.0.0/8 range,
 >>>     and any transmission within that range is source-specific.
 >>>     Within that context, INTERFACE DISCOVERY, TRANSMIT, JOIN, RECEIVE,
 >>>     and LEAVE operate the same way as described in the Native Multicast
 >>>     section.
 >>>     Some applications may wish to use SSM to provide many-to-many
 >>>     communications.  It is possible to bootstrap many-to-many by
 >>>     designating an application group leader that redistributes the (S,G=
 >>>     information about active sources down a multicast distribution tree.
 >>>     Each interested receiver then executes a source-specific JOIN
 >>>     towards the newly discovered source.
 >>>     SECURE TRANSMIT can be implemented by controlling what (S,G)
 >>>     information is propagated down the source-information multicast
 >>>     distribution tree.
 >>>     SECURE JOIN can be implemented by encrypting the information
 >>>     propagated down the source-information multicast distribution tree.
 >>>     Nickless       Informational - Expires July 2002                 5
 >>t
 >>>     network, be made IGMPv3-aware.  If properly configured by the
 >>>     network administrator, it is compatible with IPv4 routing Best
 >>>     Current Practice.  Only one copy of a multicast packet is sent or
 >>>     received by the local Designated Router.  Multicast transmission an=
 >>d
 >>>     The design and implementations of IGMP predate the PIM routing
 >>>     protocol.  However, one could imagine a host that ignores IGMP and
 >>>     speaks PIM directly with routers on the local subnetwork.
 >>>     INTERFACE DISCOVERY would have to be hard-coded or otherwise
 >>>     discovered by the implementation.  The application or host would
 >>>     implement the PIM protocol instead of the IGMP protocol.  This migh=
 >>t
 >>>     mean the host would have to discover or be configured with the
 >>>     appropriate upstream PIM speaker (PIM Designated Router) for the
 >>>     local subnetwork.
 >>>     TRANSMIT would be accomplished by encapsulating the application dat=
 >>a
 >>>     into a PIM Register message and transmitting that encapsulated data
 >>>     via unicast to the PIM Rendezvous Point.  This would happen
 >>>     relatively infrequently; most of the data would be discarded until =
 >>a
 >>>     PIM Join was received.  Given a PIM Join, the application would
 >>>     transmit directly onto the local subnetwork.
 >>>     JOIN would be accomplished by sending a PIM Join towards the local
 >>>     PIM Designated Router, refreshed appropriately.
 >>>     A variant of GROUP SIZE is accomplished as a side effect.  Until th=
 >>e
 >>>     PIM Join arrives, the application can assume that no receiver has
 >>>     expressed an interest in the data at full rate, so the application
 >>>     need not even generate the data for transmission, much less transmi=
 >>t
 >>>     it on the local subnetwork.
 >>>     Implementation of this approach requires that the host and at least
 >>>     one router on the local network speak the PIM protocol.  It is
 >>>     consistent with IPv4 routing Best Current Practice.  Only one copy
 >>>     of a multicast packet is sent or received by the local Designated
 >>>     Router.  Multicast transmission and reception is supported.
 >>>     Consider a hypothetical tunneling protocol that bypasses the local
 >>>     subnetwork of a host with an interested application.  Multicast
 >>>     packets are transmitted from a tunnel host participating in the
 >>>     native IP multicast core of the internetwork, over a TCP channel, t=
 >>o
 >>>     the application on a host.
 >>>     INTERFACE DISCOVERY requires configuration on both the tunnel host
 >>>     and the application host.  (This configuration might be automated.)
 >>>     Nickless       Informational - Expires July 2002                 6
 >>>     The application host needs to know what IP address to use to source
 >>>     packets, so that the internetwork core knows to get those packets
 >>>     from the tunnel host.
 >>a
 >>>     into the TCP channel and transmitting it to the tunnel host.  If th=
 >>e
 >>>     TCP transmit buffer is full, the application data would be
 >>>     discarded.
 >>>     JOIN and LEAVE would be accomplished by a special message through
 >>>     the TCP channel, where the application host notifies the tunnel hos=
 >>t
 >>>     of its interest (or disinterest) in data from various groups (and
 >>>     possibly specific sources.)
 >>>     RECEIVE would be accomplished by the tunnel host encapsulating data
 >>>     into the TCP channel towards the application host.  If the TCP
 >>>     transmit buffer is full, the application data would be discarded.
 >>>     The application host would decapsulate the data from the TCP stream
 >>>     and deliver it to the application in datagram form.
 >>>     TCP is preferred in this scenario because of its ability to sense
 >>>     congestion and back off appropriately.
 >>>     Implementation of this approach requires that the application host
 >>>     implement the TCP-Based Tunnel protocol, and that the application
 >>>     host be associated with at least one tunnel host.  It does not
 >>>     require that the application host subnetwork be configured for
 >>>     multicast in any way.  Given proper configuration of the tunnel
 >>>     host, it is consistent with IPv4 routing Best Current Practice.  If
 >>>     there are multiple application hosts on a given subnetwork, multipl=
 >>e
 >>>     copies of a multicast packet may be carried to that subnetwork from
 >>>     the tunnel host (one each per TCP tunnel).  Multicast transmission
 >>>     Emcast [EMCAST] is a user-level implementation of several of the
 >>>     Core Operations.  It implements the TRANSMIT, JOIN, LEAVE, and
 >>>     RECEIVE operations with library calls, and has hooks for handlers o=
 >>f
 >>>     various types.  Currently supported handlers include the traditiona=
 >>l
 >>>     Internet Multicast, Banana Tree Protocol, and Internet Relay Chat.
 >>>     Use of Emcast requires that the application support the Emcast
 >>>     library and at least one handler.  If using the Banana Tree Protoco=
 >>l
 >>>     or Internet Relay Chat handlers, it does not require that the local
 >>>     subnetwork be configured for multicast in any way.
 >>>     If Emcast was extended to support the INTERFACE DISCOVERY operation=
 >>>     specifically giving the application an internetwork-unique
 >>>     multicast-enabled IP source address, then the non-traditional user-
 >>>     level multicast forwarding schemes (e.g. Banana Tree Protocol and
 >>>     Internet Relay Chat) could be made consistent with IPv4 routing Bes=
 >>t
 >>>     Current Practice.  This would of course require some gateway
 >>>     Nickless       Informational - Expires July 2002                 7
 >>>     function between a Banana Tree Protocol or Internet Relay Chat
 >>>     domain and the IPv4 multicast core.
 >>>     Multicast technology is subject to various denial-of-service
 >>>     attacks.
 >>>     Certain host-based implementation of IP multicast forwarding are
 >>>     subject to security vulnerabilities; especially when insecure
 >>>     services are delivered IP multicast packets without first executing
 >>>     a JOIN operation.
 >>> Acknowledgements
 >>>     This work was supported by the Mathematical, Information, and
 >>>     Computational Sciences Division subprogram of the Office of Advance=
 >>d
 >>>     Scientific Computing Research, U.S. Department of Energy, under
 >>>     Contract W-31-109-Eng-38.
 >>> References
 >>>     [RFC2119] RFC 2119: Key Words for use in RFCs to Indicate
 >>>        Requirement Levels.  S. Bradner.  March 1997.
 >>>     [MCAST] RFC 1112: Host extensions for IP multicasting. S.E. Deering.
 >>>        Aug-01-1989.
 >>>     [EMCAST] http://www.junglemonkey.net/emcast by David A. Helder
 >>> Author's Address
 >>>     Bill Nickless
 >>>     Argonne National Laboratory
 >>>     9700 South Cass Avenue #221     Phone:  +1 630 252 7390
 >>>     Argonne, IL 60439               Email:  nickless at mcs.anl.gov
 >>>     Nickless       Informational - Expires July 2002                 8
 >>> =3D=3D=3D
 >>> Bill Nickless    http://www.mcs.anl.gov/people/nickless      +1 630 252=
 >> 7390
 >>> PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7     nickless at mcs.an=
 >>l.gov
 cheers
   jon
