[AG-TECH] CCS Wednesday Seminar (February 13th)
    Jennifer Teig von Hoffman
    jtvh at bu.edu
    Mon Feb 11 20:22:10 CST 2002
Thanks, I'll pass that along to the appropriate authors.
- Jennifer
On Mon, 11 Feb 2002, Alexandros A Theodoropoulos wrote:
> Hi Jennifer,
> I think I read this information in a couple of places as far as I
> can remember which are the following:
> http://www.accessgrid.org/agdp/guide/spec/2001-0824/html/control.html
> (AG Guides: Access Grid Hardware Specification)
> and
> Tutorial 1: How to Build and Install an Access Grid Node (AGN)
> An Elementary Guide for Technical Users
> I will let you know if I come up with other places.
> Regards,
> Alexandros
> On Mon, 11 Feb 2002, Jennifer Teig von Hoffman wrote:
> > Hi there,
> > Could you send me the URL(s) where you found that recommendation? The
> > author might want to update their document (or if there are links out
> > there to stale documents, we might need some changes to the AGDP web
> > site).
> > Right now old versions of documents on the AGDP remain online, with the
> > transition page for each being updated with new URLs as necessary (ie,
> > http://www.accessgrid.org/agdp/guide/spec.html always has a link to the
> > current version of the doc). But if stale links are becoming a problem I
> > may change this. (And I suppose this is as good a time as any to mention
> > that we can always use help managing the AGDP web site. :-)
> > - Jennifer
> > > >- I read in the AG documents that it is recommended that the Control
> > > >system should use either Win98 or WinME because the Gentner software
> > > >doesn't operate quite well under Win2K. Why is this so and if possible
