[AG-TECH] CCS Wednesday Seminar (February 13th)
Alexandros A Theodoropoulos aat at csit.fsu.edu
Mon Feb 11 18:21:06 CST 2002
Hi Jennifer,
I think I read this information in a couple of places as far as I
can remember which are the following:
http://www.accessgrid.org/agdp/guide/spec/2001-0824/html/control.html
(AG Guides: Access Grid Hardware Specification)
and
Tutorial 1: How to Build and Install an Access Grid Node (AGN)
An Elementary Guide for Technical Users
I will let you know if I come up with other places.
Alexandros
On Mon, 11 Feb 2002, Jennifer Teig von Hoffman wrote:
> Hi there,
> Could you send me the URL(s) where you found that recommendation? The
> author might want to update their document (or if there are links out
> there to stale documents, we might need some changes to the AGDP web
> site).
> Right now old versions of documents on the AGDP remain online, with the
> transition page for each being updated with new URLs as necessary (ie,
> http://www.accessgrid.org/agdp/guide/spec.html always has a link to the
> current version of the doc). But if stale links are becoming a problem I
> may change this. (And I suppose this is as good a time as any to mention
> that we can always use help managing the AGDP web site. :-)
> - Jennifer
> > >- I read in the AG documents that it is recommended that the Control
> > >system should use either Win98 or WinME because the Gentner software
> > >doesn't operate quite well under Win2K. Why is this so and if possible
More information about the ag-tech mailing list
