[AG-TECH] Re: AG Vic / OpenMash Vic Performance comparison
Paul B. Huang
pbhuang at bmrc.berkeley.edu
Tue Dec 3 14:00:37 CST 2002
I believe that turning off debugging will also turn on optimizations in
the makefile.vc. I'm not sure what all the flags are for the
optimizations in the visual c++ compiler. You can search for NODEBUG in
the makefile.vc and check to see if the CCOPT has the correct flags.
The numbers in the last column of the email is with debugging turned
off. There are typos in the email, mainly the (CVS) and (now) versions
should be 5.2.1 instead of 5.2.
--Paul
On Tue, 3 Dec 2002, Kabe Vanderbaan wrote:
> I see the line in the makefile to turn off debugging, but how do you compile for
> optimization? Was it compiled for optimization to get the numbers referenced below?
> http://www.openmash.org/mhonarc/openmash-developers/msg01262.html
> Kabe
> Wesley Miaw wrote:
> > On Monday, December 2, 2002, at 04:35 PM, Paul B. Huang wrote:
> >> The CVS version of OpenMash (5.2.1) should be as fast as the AG vic, if
> >> the AG vic has not been optimized significantly since April. OpenMash
> >> vic
> >> have debugging and no optimization built in by default. You have to
> >> change the makefile.vc to get the windows version to compile with
> >> optimizations and no debugging.
> > Yeah, I believe the no debug option for building doesn't exactly work
> > correctly. You need to turn off debugging and turn on optimizations
> > manually.
> > Wesley Miaw, Berkeley Multimedia Research Center
> > wesley at bmrc.berkeley.edu
> Kabe VanderBaan, Senior Research Engineer
> Networks and Infrastructure Research, Motorola Labs
> Phone: 847-576-1832
> Cell: 847-980-4100
> http://internet2.motlabs.com/agnode/
> http://internet2.motlabs.com/ipaq/
