[AG-TECH] Re: AG Vic / OpenMash Vic Performance comparison
Kabe Vanderbaan
kabev at motorola.com
Tue Dec 3 09:03:39 CST 2002
I see the line in the makefile to turn off debugging, but how do you compile for
optimization? Was it compiled for optimization to get the numbers referenced below?
http://www.openmash.org/mhonarc/openmash-developers/msg01262.html
Kabe
Wesley Miaw wrote:
> On Monday, December 2, 2002, at 04:35 PM, Paul B. Huang wrote:
>> The CVS version of OpenMash (5.2.1) should be as fast as the AG vic, if
>> the AG vic has not been optimized significantly since April. OpenMash
>> vic
>> have debugging and no optimization built in by default. You have to
>> change the makefile.vc to get the windows version to compile with
>> optimizations and no debugging.
> Yeah, I believe the no debug option for building doesn't exactly work
> correctly. You need to turn off debugging and turn on optimizations
> manually.
> Wesley Miaw, Berkeley Multimedia Research Center
> wesley at bmrc.berkeley.edu
Kabe VanderBaan, Senior Research Engineer
Networks and Infrastructure Research, Motorola Labs
Phone: 847-576-1832
Cell: 847-980-4100
http://internet2.motlabs.com/agnode/
http://internet2.motlabs.com/ipaq/
