[AG-TECH] Re: AG Vic / OpenMash Vic Performance comparison
Wesley Miaw
wesley at bmrc.berkeley.edu
Mon Dec 2 15:42:31 CST 2002
On Monday, December 2, 2002, at 04:35 PM, Paul B. Huang wrote:
> The CVS version of OpenMash (5.2.1) should be as fast as the AG vic, if
> the AG vic has not been optimized significantly since April. OpenMash
> vic
> have debugging and no optimization built in by default. You have to
> change the makefile.vc to get the windows version to compile with
> optimizations and no debugging.
Yeah, I believe the no debug option for building doesn't exactly work
correctly. You need to turn off debugging and turn on optimizations
manually.
Wesley Miaw, Berkeley Multimedia Research Center
