[AG-TECH] Re: AG Vic / OpenMash Vic Performance comparison
Paul B. Huang
pbhuang at bmrc.berkeley.edu
Mon Dec 2 15:35:19 CST 2002
I believe this issue was brought up in April. The thread on the OpenMash
list is:
http://www.openmash.org/mhonarc/openmash-developers/msg01262.html
The CVS version of OpenMash (5.2.1) should be as fast as the AG vic, if
the AG vic has not been optimized significantly since April. OpenMash vic
have debugging and no optimization built in by default. You have to
change the makefile.vc to get the windows version to compile with
optimizations and no debugging.
--Paul
On Mon, 2 Dec 2002, Kabe Vanderbaan wrote:
> Hello All,
> We have started trying to use OpenMash vic as part of our research. However, OM vic
> appears to have certain performance issues that we did not see in AG vic.
> For instance, when there are apx 12 feeds available, and we try to choose all 12
> feeds to display on the screen, it takes longer and longer for the windows to show up
> on the screen after selecting the thumbnail. In fact, There is a good 20 seconds
> before OM vic will respond to even a mouse click.
> We are testing on a Dual 650Mhz Processor Pentium III running Windows 2000. We have
> tested both on this machine and do not see the performance issues when using AG vic.
> We have used both OM 5.2 and from CVS, and have compiled it using the performance
> enhancements (Without Debug).
> We need to do some development, and would like to use OM vic, but we cannot give up
> the performance of AG vic. So, I have some questions below.
> Has anyone else experienced the above problems?
> Has anyone done a performance test between AG vic and OM vic?
> Does a fix, or a workaround exist for this at all?
> Thanks,
> Kabe
> Kabe VanderBaan, Senior Research Engineer
> Networks and Infrastructure Research, Motorola Labs
> Phone: 847-576-1832
> Cell: 847-980-4100
> http://internet2.motlabs.com/agnode/
> http://internet2.motlabs.com/ipaq/
