[AG-TECH] FW: [AVT] Multiple IP address scenarios in a multicast environment
Jay Beavers
jbeavers at microsoft.com
Thu Aug 29 12:15:04 CDT 2002
I get excellent image quality from the Logitech. However, I'm using
Windows XP, Directshow capture interfaces, and Windows Media
compressors/decompressors with the ConferenceXP software, so there's a
lot of variance between software implementations.
-----Original Message-----
Sent: Thursday, August 29, 2002 10:02 AM
To: Jay Beavers
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] FW: [AVT] Multiple IP address scenarios in a
Jay,
Just curious - on your PIG with the USB camera, are you having the
problem that I and others have been having with the bluish tint?
Darin Oman
NCAR
Jay Beavers wrote:
We're just using standard tower workstations -- a Dell Precision 530 for
instance. For smaller environments, I'm using the smaller form factor
PCs like the mini configuration Precision 340. The holdup there has
been the lack of a good half height AGP video card with multiple video
outs.
I've finally got a hold of a half height AGP NVIDIA Quadro4 NVS 200
which drives two displays. If you're doing small nodes (1-3 cameras,
1-2 displays), the combination of a Precision 340 with the Quadro4 would
be great -- 2'x2'x4". For most AG node scenarios though, I'd stick with
the Precision 530.
We've been trying out laptop portable nodes, but we're still faced with
three problems:
* Laptops come with 1394, but without power so a clunky external 1394
powered hub with power adapter is needed, or we have to stick with 1 USB
camera (Logitech QuickCam Pro 3000)
* Pushing large amounts of multicast over wireless 802.
11a has failed
on our first set of 802.11a equipment (Proxim Harmony). 802.11b is
working OK, but isn't a scalable solution.
* A Gentner XAP-400 et al is a little hard to move around ;-) and the
ClearOne didn't work well enough to replace it.
The first two aren't showstoppers for laptop deployments, but the third
is.
- jcb
From: Jonathan C. Humfrey [mailto:jch at cs.ucsb.edu]
Sent: Thursday, August 29, 2002 9:02 AM
To: Jay Beavers
Cc: Osland, CD (Chris) ; ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] FW: [AVT] Multiple IP address scenarios in a
Jay,
Can you tell me what the exact setup of your display machine is? Are
they
rackmount? I have had a real problem with our display machine which
uses
a SuperM
icro motherboard made for a server and we end up getting a lot
of
loss in the rendering process... we're looking for a rackmount dual
processor machine that will render much more effectively. Any
suggestions?
Jonathan
On Thu, 29 Aug 2002, Jay Beavers wrote:
We're using 1394 cameras in addition to analog PCI based capture
cards.
1394 cameras have many advantages (integrated power, control,
and data
cables; higher quality all-digital signal; lower CPU
utilization) and
one of them is that realistically you can fit 3 cameras per PCI
slot.
In other work at MSResearch that involve camera arrays, they use
5+
1394
cameras running at 640x480 and software to create one very
large,
highly
detailed image that appears as one virtual large video source.
You
can
see this in the papers on the 'Ring Camera'. This isn't ready
for
AG-like scenario trials yet, as it's still in early prototype
stage.
With the continuing march upwards in PC capacity, I don't
foresee
multi-node computers as being required by number or quality of
video
streams. We're quite happy doing multiple capture and multiple
render
streams on our dual P-IV workstations today, and we could easily
go up
in capacity over 50% by moving from our 1.7 GHz CPUs to 2.8 GHz
CPUs
that are now available (and go from 400 MHz dual channel RD-RAM
to 533
MHz dual channel RD-RAM at the same time). We take advantage of
the
CPU
assist provided by cards like the NVIDIA GeForce and the DirectX
Video
Acceleration architecture that is part of DirectShow which
allows the
graphics card to offload significant portions of the decoding
and
rendering.
We are using multiple computers per node now for pure logistical
reasons. We're using one computer to handle all the A/V
traffic, a
wireless Tablet PC to drive PowerPoint with ink, and a laptop as
the
administrative/diagnostic console. Our hope is to make the
administrative console needed only for occasional onsite
diagnostics
(like adjusting the microphone gain/gating settings for the
room) as
operations continues to get simpler. Our admin console used to
be on
the A/V node, but we found it is too disruptive to use to have
the
operator run over to the A/V node whenever any adjustments need
to be
made ;-) We're looking at other solutions, like moving the A/V
node
to
an operations closet or using Mira devices (LCD monitors with
Remote
Desktop logic built in) or providing a web-based admin interface
directly on the A/V node to keep the Admin functions integrated
on the
A/V node.
We can make signals from multiple computers 'appear' to be from
one
logical place by sending signals from the same CName, at least
until
we
start using SSM and then the IP address becomes important. I
don't
have
a clear concept of whether we would ever use the same CName
among more
than one computer. In our scenario, education, we generally
give a
'room' CName to the A/V workstation (E.G.
MSR-113-1021 at Microsoft.Com)
and use a 'professor' CName (E.G. DrBob at Washington.Edu) for the
Tablet
PC and an 'operator' CName (E.G. JBeavers at Microsoft.Com) for the
operator's console. Strictly speaking, what's a "node" in that
design
and what are just "personal" devices?
- jcb
From: Osland, CD (Chris) [mailto:C.D.Osland at rl.ac.uk]
Sent: Thursday, August 29, 2002 7:21 AM
To: Jay Beavers; ag-tech at mcs.anl.gov
in a
It may not be relevant (I'm not in any sense a network type
person)
but I foresee a requirement for more than one capture computer
to
be regarded as part of a single node. There are already times
when
I would like to put out more than 4 video streams, and I also
want
to start to use higher bandwidth links (e.g. 640x480, 800x600
and
1024x768 off computers). There aren't many motherboards with
more
than 6 PCI slots, and with one gone on networking, a second
video
capture computer that appeared seamlessly in the venue would be
a
bonus.
I don't know whether this requires what you are discussing; if
it
doesn't, please ignore!
Cheers
Chris Osland
____________________________________________________________________
Chris Osland
Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235
446459
BIT Department Access Grid room tel: +44 (0) 1235
445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235
445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and
are for the use of the intended recipient only.
If you are not the intended recipient do not take
any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
From: Jay Beavers [mailto:jbeavers at microsoft.com]
Sent: 29 August 2002 06:19
To: ag <mailto:ag-tech at mcs.anl.gov>
-tech at mcs.anl.gov <mailto:ag-tech at mcs.anl.gov>
Subject: [AG-TECH] FW: [AVT] Multiple IP address scenarios in a
FYI, thought I would forward over this discussion I started on
the
IETF
AVT mailing list (AVT owns RTP, the transport of AG).
We're looking into enabling browsing of active participants in
Venues
that you're interested in but not joined to, as well as thinking
about
tiering multicast traffic between 'important' and 'less
important'
streams.
If anyone on AG-Tech has thoughts in this area, I'd love to hear
them.
- jcb
Sent: Tuesday, August 27, 2002 12:10 PM
To: Jay Beavers
Cc: avt at ietf.org
Subject: Re: [AVT] Multiple IP address scenarios in a multicast
environment
Comments inline...
--> "Jay Beavers" writes:
Scenario 1, Who's Talking?
An application is using RTP over multicast UDP on an
IPv4, IGMPv2
network. When a client subscribes to a multicast group
address using
IGMPv2, the client receives all traffic on that
multicast group
address,
including all RTP and RTCP traffic, regardless of sender
or port.
The client application can join any one of 30 available
multicast
group
addresses. The list of possible multicast group
addresses and their
associated details is obtained via a unicast query once
at the start
of
the client application. The client wants to get some
information
about
who is in each multicast group, preferably by receiving
the RTCP SDES
traffic from each multicast group on port 5005.
For discussion sake, there are five clients in each
multicast group,
each client sending 1 Mb/s of RTP traffic. Each client
is assumed to
have at least 10 Mb/s of quality connectivity to an
unloaded network
backbone.
Problem 1:
If the client application sends a multicast group
address join
request
for all 30 multicast group addresses, they will receive
the RTCP SDES
traffic, but also the RTP traffic from each multicast
group. This
works
out to 30 * 5 * 1 Mb/s = 150 Mb/s of aggregate traffic,
vastly
exceeding
the 10 Mb/s client network capacity.
Potential Solution 1:
Are there any thoughts about how to approach this? I
hesitate to
load
group membership state on a server due to scalability,
reliability,
and
stale data concerns.
Valid concerns. If you did choose this approach, a well
connected
group
member could listen to the RTCP and allow SNMP queries (the RTP
MIB
can
provide SDES information).
Source Specific Multicast wouldn't solve this, as I
would need to
subscribe to all sources to receive their RTCP traffic
which would
also
bring down their RTP traffic unless RTP and RTCP were
separated onto
separate IP addresses. I've also wondered if RTCP SDES
traffic could
be
duplicated to one shared multicast group address, the
problem being
knowing which SSRCs are associated with which multicast
group
addresses
(associated by a RTCP APP packet perhaps?)
Or use two multicast groups per session, one for the data and
one for
the
RTCP?
Scenario 2, We're All Equal, But Some Are More Equal
Than Others:
The same application is running, but the number of
participants has
increased, perhaps because the conversations are using a
lecture or
panel discussion model. Now we have a few (5?)
important clients and
50
less important clients.
It's decided that the important clients should continue
sending the 1
Mb/s of data. Less important clients can send an
occasional (every
30
seconds) high resolution snapshot as well as 100 kb/s of
A/V streams.
If all data is sent over one multicast group address,
the aggregate
network bandwidth is 5 * 1 Mb/s + 50 * 100 kb/s = 10
Mb/s, severely
stretching the network capacity of the clients. The
clients would
prefer to receive the streams for important clients and
the snapshots
for less important clients. Optionally, the 100 kb/s
streams from
the
less important clients would be enabled on a stream by
stream basis.
Problem 2:
Source Specific Multicast has some relevance here, as it
could be
used
to subscribe to a subset of the less important client
A/V streams.
However, the client would still want to receive RTCP and
snapshot
information from all clients.
Potential Solution 2:
Traffic could be broken into two multicast group
addresses again,
with
unfiltered traffic (RTCP, RTP snapshots) being on one
address and
source
filtered traffic (RTP A/V streams) being on a separate
address. This
would also allow IGMPv2 networks to work, as clients on
that network
could subscribe to only the traffic on the unfiltered
multicast group
address and lose only the capacity to see A/V streams
from the less
important clients.
You could also run two RTP sessions, one for the "important"
clients,
and
one for the rest, each with their own RTCP. The CNAME fields
would let
you
relate participants between the sessions.
In both these cases, the solution involves sending RTCP
on a separate
IP
address from its associated RTP streams, which certainly
isn't
mentioned
in RFC 1889 anywhere. Any other thoughts on how to
approach these
scenarios?
See above. I don't have strong objections to sending RTCP on a
separate
multicast group to the associated RTP, in the first example.
Colin
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020829/cb080898/attachment-0001.htm>
