[AG-TECH] VIC on display machine
Michael Gates
mgates at SDSC.EDU
Mon Apr 29 08:33:50 CDT 2002
Unfortunately, we run AG-Ware on a seperate machine. Anyone else out
there have trouble with the latest release of the nvidia drivers (ver
28.32)? I can't seem to get them to 'stick' either. Also, what
versions of DirectX is everyone running?
Thanks for all the help so far!
-Mike
> Just a thought - you're not running the AGware software on the
> same machine are you? We do, and if we don't set the priority of
> AGware right down, it kills the performance of vic. (Someone
> was kind enough to tell us the means of doing this - Task Manager,
> Processes tab, right click on process, Set Priority, Low).
> Cheers
> Chris
> ____________________________________________________________________
> Chris Osland Office tel: +44 (0) 1235 446565
> Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
> BIT Department Access Grid room tel: +44 (0) 1235 445666
> e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
> CLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and
> are for the use of the intended recipient only.
> If you are not the intended recipient do not take
> any action on it or show it to anyone else,
> but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: Michael Gates [mailto:mgates at SDSC.EDU]
> Sent: 26 April 2002 18:38
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] VIC on display machine
> I'm having a lot of trouble with VIC on my display machine. It is
pegging
> the cpu and is unresposive to moving of windows (the video in each
window
> still shows and moves). I have had this problem with both vic and
ddvic.
> My display machine is a Windows PC, and I have this same problem in
both
> Windows 2000 and windows XP on both PIII and P4 machines. The video
cards
> I am running are Geforce2 Mx400s (pci) and Either an integrated ATI
or an
> AGP Geforce2 256.
> This problem makes it impossible for me to setup a display wall and
change
> views for different presenters.
> Any ideas out there in AG land?
> Thanks,
> -Michael Gates
> SDSC
