[AG-TECH] AGAudio redhat 7.x
Robert Olson
olson at mcs.anl.gov
Mon Oct 29 12:16:48 CST 2001
What audio card are you using? Is it one the ones that is on the card list
at opensound.com?
I'm not sure I've tried using that RPM with 7.1 or not; you may have to
download the driver package from opensound directly.
--bob
At 11:59 AM 10/29/2001 -0600, Kabe Vanderbaan wrote:
>Yes, I am having problems instaling the oss drivers.
>Here's what I did:
>I installed a clean version of redhat 7.2,
>I ran this update script:
>http://ag-tech.mcs.anl.gov/reldb/repository/releases/agib/snapshots/snap-006/
>added /usr/local/ag/bin to my path
>I then beagna to follow the instructions for a "standard" setup:
>http://www.accessgrid.org/agdp/guide/building-an-access-grid-node/2.4.4/html/x216.htm
>I get through 3f, but then it says that it is not compatible with the
>kernel.
>I try to download the file, and to compile locally, but no luck. I exit
>and get this:
>OSS installer was not able to find a suitable sndshield
>module for your system.
>Instructions for fixing the situation manually are given
>in /usr/lib/oss/docs/README.sndshield.
>/usr/lib/oss/install.log contains more debugging info.
>/usr/lib/oss/docs/README.sndshield does not exist.
>Any Help?
>Kabe
>Bob Olson wrote:
> > Yes; are you having any probelms in particular?
> > --bob
> > On Mon, 29 Oct 2001, Kabe Vanderbaan wrote:
> > > Has anyone been successful at getting the agaudio machine to run under
> > > 7.x?
> > > Kabe
> > > Kabe VanderBaan, Research Engineer
> > > Networks and Infrastructure Research, Motorola Labs
> > > Phone: 847-576-1832
> > > Cell: 847-980-4100
>Phone: 847-576-1832
>Cell: 847-980-4100
