[AG-TECH] Multicast beacon questions
Satish Devarapalli
devasat at iit.edu
Fri Oct 26 10:32:45 CDT 2001
small correction in my previous mail..
" how to add myself in to the multicast group without logging in to the
Virtual Venues."
Has anyone tried this tool ?
-Satish
-- Original Message --
>hi,
>There is a similar tool at
>http://www.web3d.org/WorkingGroups/vrtp/rtpMonitor/
>-presents global session statistics, individual stream statistics and feedbacks
>from all participants;
>- records the statistics in text files, continuously, in intervals defined
>by the user;
>the statistics recorded might be useful for debugging problems and improving
>QoS.
>I tried running on my Win2K box, but i get some errors
>with out logging in to the VirtualVenues i tried running this and i get
>an error message "Cannot bind requested address",
>after logging in i get "cannot bind:requested address in use"
>i tried to trace the problem, this message is coming from RtpMonitor code,
> but couldnt figure out the exact cause for this exception.
>can some one tell me what is going on when i log in to the virtual venues.
>my understanding is that i will be added to the multicast group address
>to which the venue is bound, **but how is this done exactly**. i mean are
>my credentials or ipaddress is used to add me in to the multicast group.
>becoz, the error message "Cannot bind requested address" indicates me some
>security problem or that i am not added in the multicast group. how to
add
>myself in to the multicast group without logging in to the multicast group
>so that i can run my rtpMonitor.
>Any pointers please ??
>BTW, my network is enabled for Multicast and i am receiving the multicast
>traffic.
>Thanks
>Satish Devarapalli
>Illinois Institute of Technology
>>hey,
>>a pointer that might be helpful is:
>>http://www-mice.cs.ucl.ac.uk/multimedia/software/rqm/
>>it's a rtp/rtcp based monitor of a group. This would be pointed *at*
the
>>audio or video group and tell you information on that group. I believe
>>the
>>statistics are less network based and more application based, but that
>might
>>not be a bad thing.
>>It's probably not a replacement for the beacon, but it might be another
>>level of information that's helpful and less taxing.
>>--Ivan
>>> -----Original Message-----
>>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
>>> Behalf Of Chris Greenhalgh
>>> Sent: Friday, October 26, 2001 3:07 AM
>>> To: Tony Rimovsky
>>> Cc: ag-tech at mcs.anl.gov; Chris Greenhalgh
>>> Subject: Re: [AG-TECH] Multicast beacon questions
>>> > I understand your concern about beacon scalability. We will be
>>> > examining mechanisms such as using RTP data in order to try to lower
>>> > the overhead of using the beacon in large communities.
>>> I gather there are at least three candidate mechanisms for RTCP
>>> aggregate bandwidth management (scaling each sender's rate so
>>> that the total of all senders is bounded; in RTP/RTCP this is to some
>>> fraction of the total data traffic). This would seem an obvious place
>>to
>>> look, as long as noone is relying on '10pps' as a magic number
>>> Chris Greenhalgh
