[AG-TECH] Multicast beacon questions
Satish Devarapalli
devasat at iit.edu
Mon Oct 29 20:01:11 CST 2001
hi,
I have resolved the problem and able to get the RTP Statistics.
It was a bug in java code, not my multicast. It was weird error, the program
was not able to connect to the multicast session and gave me the error
"Cannot bind requested address". Later i disabled my network and ran the
program, it still gave me the same error,with no network connection on the
machine, and so thought problem with the code. after a long investigation
i figured out and finally it works :-) There was a problem connecting to
the multicast session using Programs written in JMF1.2, as the current version
now is 2.0 and some changes were made. I also have a sample program which
connects to the multicast sessison and plays the incoming video stream,
really cool. so probably we might plan rewriting vic in Java, to get the
platform independence and all its features.
If any one is interested in trying this tool let me know, i can send you
the modifed version.
Thanks for all your help,
Satish Devarapalli
Illinois Institute of Technology
Chicago, IL-60616
-- Original Message --
>hi,
>There is a similar tool at
>http://www.web3d.org/WorkingGroups/vrtp/rtpMonitor/
>-presents global session statistics, individual stream statistics and feedbacks
>from all participants;
>- records the statistics in text files, continuously, in intervals defined
>by the user;
>the statistics recorded might be useful for debugging problems and improving
>QoS.
>I tried running on my Win2K box, but i get some errors
>with out logging in to the VirtualVenues i tried running this and i get
>an error message "Cannot bind requested address",
>after logging in i get "cannot bind:requested address in use"
>i tried to trace the problem, this message is coming from RtpMonitor code,
> but couldnt figure out the exact cause for this exception.
>can some one tell me what is going on when i log in to the virtual venues.
>my understanding is that i will be added to the multicast group address
>to which the venue is bound, **but how is this done exactly**. i mean are
>my credentials or ipaddress is used to add me in to the multicast group.
>becoz, the error message "Cannot bind requested address" indicates me some
>security problem or that i am not added in the multicast group. how to
add
>myself in to the multicast group without logging in to the multicast group
>so that i can run my rtpMonitor.
>Any pointers please ??
>BTW, my network is enabled for Multicast and i am receiving the multicast
>traffic.
>Thanks
>Satish Devarapalli
>>hey,
>>a pointer that might be helpful is:
>>http://www-mice.cs.ucl.ac.uk/multimedia/software/rqm/
>>it's a rtp/rtcp based monitor of a group. This would be pointed *at*
the
>>audio or video group and tell you information on that group. I believe
>>the
>>statistics are less network based and more application based, but that
>might
>>not be a bad thing.
>>It's probably not a replacement for the beacon, but it might be another
>>level of information that's helpful and less taxing.
>>--Ivan
>>> -----Original Message-----
>>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
>>> Behalf Of Chris Greenhalgh
>>> Sent: Friday, October 26, 2001 3:07 AM
>>> To: Tony Rimovsky
>>> Cc: ag-tech at mcs.anl.gov; Chris Greenhalgh
>>> Subject: Re: [AG-TECH] Multicast beacon questions
>>> > I understand your concern about beacon scalability. We will be
>>> > examining mechanisms such as using RTP data in order to try to lower
>>> > the overhead of using the beacon in large communities.
>>> I gather there are at least three candidate mechanisms for RTCP
>>> aggregate bandwidth management (scaling each sender's rate so
>>> that the total of all senders is bounded; in RTP/RTCP this is to some
>>> fraction of the total data traffic). This would seem an obvious place
>>to
>>> look, as long as noone is relying on '10pps' as a magic number
>>> Chris Greenhalgh
